You could run the signal in through the antenna wire. Its a completely invisible/removeable solution. Then you just tune the radio to a specified staion to recieve the empeg signal. ***You must buy a good "modulator" to do this. Don't buy a cheap transmitter. Get one that plugs inline with the antenna wire. If you don't you will be very unhappy. I installed a Kenwood CD changer in a motorhome this way and the sound is perfect. I don't know who makes a good standalone one though. I know they are out there. Check crutchfield or maybe someone could point in the right direction.
Alex Lear
Alex Lear
