I found a tiny black rubber band that i believe is used for hair extension type braids that works perfectly and looks like it belongs there. Just a suggestion. If you wanted to get really fancy you could take a Dremmel and route out a small groove for the rubber band to sit in, now that would be fancy. I've seen rubber O rings that would probably work perfectly as well...I'm going to do some hardware store research this weekend and see what i come up with.
|| loren.cox
|| 080000446
|| loren ||
