#200385 - 26/01/2004 13:55
Re: Hijack v356, v357, v358, v359, and soon.. v360
The hardware appears to have the capability to generate a powerfail interrupt when the car power supply drops below about 10VDC. When this happens, the kernel does a number of things, including muting the audio, writing the 128byte flash savearea, and blanking the display.
Software also disables the powerfail detection, so that the interrupt doesn't just keep interrupting things -- polling is used to detect when the powerfail trigger goes away -- voltage above 10VDC again.
The player software "sees" this by looking at /proc/empeg_power, where there is a bit labelled "1 (Powerfail enabled)". When this shows up as "0", the player displays the battery icon. When it shows as "1", the player does not display the battery icon.
EDIT: there does not appear to be a way to read the actual voltage, but rather just the trigger for above/below 10VDC.
Edited by mlord (26/01/2004 13:56)
foxtrot_xray
25/01/2004 14:48
SE_Sport_Driver
25/01/2004 15:01
SE_Sport_Driver
25/01/2004 14:49
Hijack v360
Re: Hijack v360
Re: Hijack v360
Daria
25/01/2004 17:51
Re: Hijack v360
Re: Hijack v360
SE_Sport_Driver
25/01/2004 18:36
Re: Hijack v360
Re: Hijack v360
Daria
25/01/2004 23:16
Re: Hijack v360
Re: Hijack v360
Daria
26/01/2004 16:50
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
speedy67
30/01/2004 18:23
ShadowMan
26/01/2004 07:10
pgrzelak
26/01/2004 07:36
TigerJimmy
26/01/2004 10:00
paulj
26/01/2004 15:39
Daria
26/01/2004 16:33
SE_Sport_Driver
26/01/2004 16:47
Mataglap
26/01/2004 17:01
