So did you try the 1k resistor or not?
I didn't. From the description, it seemed to me that the behavior of the antenna should be more erratic (like going up at the right time, but not going down correctly or vice versa). Mine is consistently up when the player is on and only goes down once I switch it off. Since the description didn't match my symptoms, I figured that couldn't be the problem and didn't try it. It sounded like the voltage, once applied wouldn't go down enough. Silly me, I didn't consider the possibility, that the antenna relais actually could draw voltage from the tuner, even if it never was switched on.
I have a Miata. Maybe someone knows if their antennae have this problem? Anyway, if that's the last thing I can try, I'll go back and dig into the dash and add that resistor, definitely.
Thanks for your help, guys!
32MB, serial: 10101626
