#250773 - 02/03/2005 17:11
Re: Another good question: AutoPowerOff feature ?
[Re: Thorgal]
Quote: Txs for the tips. I will modify the INI file because I dont want to change the power wires. I want to continue to listent to music even if I switch off the car (I only have a kind of ON/OFF key in the car, so when I switch off the engine, there is no more power in the car even not the cigarettes lighter...)
That all sounds like any car I've ever worked on, including my own. The ignition switch is SUPPOSED to be an ON/OFF thing -- nothing unusual there. Again, your Empeg is installed incorrectly, and if you fix that, the rest will behave like you want it to.
EDIT: but without an ACC key position, the amplifier would still be a nuisance, I suppose.
Edited by mlord (02/03/2005 17:12)
