The sinewave and pink noise generators would, IMHO, only be useful in conjunction with an RTA system.
The discussion of an automatic spectrum analyser has happened before. I really like the idea, and would love to see it implemented. There is a problem, though, which is the mic input can't sample the really high frequencies. I forget where its upper limit is, but it's within the range of normal hearing. Still, if the RTA system could just cover all the other frequencies, it would be cool.
You know, someone could simply WRITE one. It doesn't have to be integrated into the player software...
In the meantime, you can create your own sine waves, frequency sweeps, and pink noise bursts in Cool Edit. I've done that very thing, it's really easy. When 1.1 comes out, you'll even be able to put them on the Empeg as native WAV files without having to compress them first.
___________
