#300774 - 20/07/2007 19:30
Re: Help with rebuilding MK2 and new HD
Same problem:
ide_data_test: wrote 0x5555 read 0x5d55 hda: FUJITSU MHK2060AT, ATA DISK drive ide0: RAMDISK: ext2 filAC 00:02:d7:26:0b:b7 Partition check: hda20 blocks [1 disk] into ram disk... ck 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root05: rw=0, want=2, limit=0 dev 03:0ess beyond end of device 03:el panic: VFS: Unable to mount root fs on 03:05 uperblock Kernel panic: VFS: Unable to mount root fs on 03:05 uperblock Kernel panic: VFS: Unable to mount root fs on 03:05 ----------------------------------
I have been able to partiton and format this drive just fine as well as run an fsck on it with no errors.
So, pop the drive out onto a usb cable (or something) to connect to a PC running Linux, and then do "fdisk -l" on it, and post the results here.
From the notes above, the drive appears to have NOT been partitioned (aka. "built").
Edited by mlord (20/07/2007 19:30)
