Also, I found
this really cheap sensor, which supposedly can be controlled by simple windows software.
The good is it's inexpensive. The bad...
It's intended to operate stand alone, be retrieved and read on a computer.
It only operates from the internal battery, which is not rechargeable. The usb port will not supply power to operate the logger.
When connected to the usb port it presents as a file system containing a csv file containing the logged times and temps.
There is an app that allows setting the log intervals. Longer intervals allows longer operation before the battery gives out.
