Disk is very much functioning fine. So perhaps the builder didn't finish formatting or populating the filesystems?
Okay, I just ran bigdisk-v3-alt, and followed that with v3alpha11. Bigdisk appears to have failed to run, which is why both Tony and I see the various errors afterward.
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initsh: error in load
I'm going to try running bigdisk again, after first doing "hdparm --security-erase" on the drive to zero it and delete all partitions.
