#10528 - 03/07/2000 12:34 MK2: Redled/front q's
jfranke
Just two questions on the MK2: What is the red led inside for ?
The front filter plastic doesn't seem to have the EMC grid in there. Is it now 'normal' filter plastic ? Cheers, tx, J.
#10529 - 03/07/2000 12:51 Re: MK2: Redled/front q's [Re: jfranke]
When Hugo demoed the MK2 prototype for me, he remarked that it was now a clear spray coating on the inner surface instead of the wire mesh. Amazing what they can do with technology, isn't it? (And it sounds like it would be cheaper to manufacture, too.)
#10530 - 03/07/2000 15:17 Re: MK2: Redled/front q's [Re: tfabris]
jfranke
Thanks, so no 'stabdard' plastic....too bad, I wanted to make myself a pink front. J.
#10531 - 03/07/2000 16:38 Re: MK2: Redled/front q's [Re: jfranke]
The red led is a diagnosis led. It does some flashing in test mode (ctrl-T at the reflasher prompt on power on). The mk1 had one too, except it was yellow and harder to see from the outside of the case.
#10532 - 03/07/2000 23:27 Re: MK2: Redled/front q's [Re: jfranke]
Henno
Loc: Meije, Netherlands
What is the red led inside for ?/orange]
Do you mean the small LED next to the USB port? In my Mark2 this isn't red, but shines blue . . .
Henno
ex 00120; scored Mark2 nr: 006;
#10533 - 04/07/2000 00:52 Re: MK2: Redled/front q's [Re: Henno]
The LED by the USB port is the ethernet link led. It comes on at power up, then goes off when ethernet is initialised.
The internal red led is something else altogether, and is near the right-side cooling holes.
