#127450 - 21/11/2002 20:07 Stuck at "Working" on Jemplode - (I Posted Log)
DirtyDozen
Loc: ... they call us Massholes
After uploading new files to player, it froze, but I thought nothing of it. All file's were succesfully done.
I just tried to open Jemplode, and it got, up-to filling all the "rogress bars", and does nothing...
I found stated error's, except dont know what they meen:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 40104276)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 00002440 '@$'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:b
4
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
Vcb: 0x4086d000
????THANK'S????
(... regards to all.) [orange]- DirtyDozen[/orange]
#127451 - 22/11/2002 05:39 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: DirtyDozen]
mschrag
Loc: Richmond, VA
I don't see any errors on the Empeg side (those look like normal startup messages). What version of jEmplode are you using (says in the title bar)?
#127452 - 22/11/2002 12:34 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: mschrag]
DirtyDozen
Version 44
Thank's,
- DirtyDozen
#127453 - 22/11/2002 12:36 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: mschrag]
DirtyDozen
(Taken from above) This is normal?:
Mounting proc
#127454 - 22/11/2002 13:37 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: DirtyDozen]
mtempsch
If it's a one drive unit, then yes.
/dev/hda4 is the first (only on a single drive) music partition. For some reason I don't recall, they first try to mount it as a Reiser-filesystem (which it isn't, it's ext2), then it does get mounted as ext2.
/dev/hdc4 is the second music partition - only present on 2 drive units. So on a 1 drive unit it can't be found, hence the error.
#127455 - 22/11/2002 13:55 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: DirtyDozen]
mschrag
Loc: Richmond, VA
Oh .. didn't notice that my bad..
#127456 - 25/11/2002 05:06 Re: Stuck at "Working" on Jemplode - (I Posted Log [Re: mtempsch]
Because on the Rio Central, it is ReiserFS.
