#133299 - 06/01/2003 06:26 Why is there a 'thump' from my amplifiers ....
PKi
Loc: Poland
when i turn off the ignition. I have an MK1 powered from the ignition.
MK I - 00158
#133300 - 06/01/2003 10:38 Re: Why is there a 'thump' from my amplifiers .... [Re: PKi]
Even a Mk1 shouldn't thump like that if it's properly wired. Can you describe the way things are wired-up in more detail? Where is the amp getting its power, and where is the amp-remote wire connection?
#133301 - 11/01/2003 23:27 Re: Why is there a 'thump' from my amplifiers .... [Re: tfabris]
PKi
Loc: Poland
Now i can tell you the following:
ampliefers are wired as usual. plus over 100A directly from car battery, remote to empeg-remote-wire. empeg plus is now over a switch to plus (not ignition plus).
turning empeg off with the switch or even pressing and holding the top button produces a thump..
the problem i dont have with other radios, i had a blaupunkt, a panasonic and a kenwood installed before, there was no problem.
MK I - 00158
