#152720 - 02/04/2003 15:01 Browsing v2.00 visuals with Hijack
If you have not tried this yet, then give it a go.
Use this translation in config.ini:
[ir_translate]
Visual.L=Visual.L
Visual=VisualSeek
With v2.00-final installed, and Hijack, do a short press of the "visuals" button on the Rio Remote. It should pop-up a "Visuals" label on the screen, and while that label is active, you can use the knob and/or RioRemote Next/Prev track buttons to scroll forward AND backward through the available choices.
A long press of Visuals works same as before, toggling the "Favorites" mode.
Edited by mlord (02/04/2003 17:16)
#152721 - 02/04/2003 15:12 Re: Browsing v2.00 visuals with Hijack [Re: mlord]
Memil
Loc: Sweden
Great feature!
But I'm feeling stupid(as usual... )..
But I can't get it to work with 2.00-final and hj-324?
I'm running in ac-mode now, maybe thats has something to do with it? Testing in car tomorrow...
/Fredrik
#152722 - 02/04/2003 15:18 Re: Browsing v2.00 visuals with Hijack [Re: mlord]
genixia
Hmm. Not seeing that with the remote. (v2.00-final + HJ320-variant, no IR translations). It continues to change forward one visual.
I've managed to find Visualseek mode through the knob press though, and it is very cool.
#152723 - 02/04/2003 15:26 Re: Browsing v2.00 visuals with Hijack [Re: mlord]
Oh shoot.. that's right. It's OFF by default.
Darn.. okay, ya have to use this translation in config.ini:
[ir_translate]
Visual.L=Visual.L
Visual=VisualSeek
There's also a "VisualSeek" virtual function (used above) that you can bind to any button you like, or to a PopUp menu. It's even already on the default PopUp0 menu, which you can enable for short knob presses via the Hijack menu.
#152724 - 02/04/2003 15:32 Re: Browsing v2.00 visuals with Hijack [Re: mlord]
Memil
Loc: Sweden
Ah, now it works much better :-)
Thanks!
/Fredrik
