#154489 - 09/04/2003 12:57 Dead EMPEG!!! Help!
sirmanson
Loc: Tucson, AZ USA
I decided to add some cool new Jemplode Soup Playlists to my MK2a (2.0b13 - Hijack 329) ... During the synchronization I got a java error (I don't remember what it was) and the synch failed. Now when I reboot the player it displays the "Building Databases" message. The first few times it would act like the rebuild was complete, but would start to play the current song in the playlist and would freeze (I could get to hijack at this point, but nothing else). Currently it doesn't ever seem to complete the rebuild. Because of this I can't connect to it using Emplode or Jemplode. Can someone please offer some suggestions??
Thanks,
Aaron
Edited by sirmanson (09/04/2003 13:04)
----- RioCar 60gb
#154490 - 09/04/2003 13:03 Re: Dead EMPEG!!! Help! [Re: sirmanson]
sirmanson
Loc: Tucson, AZ USA
I was connecting through the network when this died and since then I have tried connecting through USB as well with no luck.
----- RioCar 60gb
#154491 - 09/04/2003 13:10 Re: Dead EMPEG!!! Help! [Re: sirmanson]
Oh-oh. First of all, put 2.0-final on; it fixes some cases of persistent database rebuild failure. If rebuilding databases still crashes or fails to complete even under 2.0-final, then we're looking at using the shell prompt to manually remove whatever is causing the problem. For that reason, it's a good idea to put on 2.0-developer, not consumer. (Being a developer image doesn't affect normal use of the player, it just lets us get you to a shell prompt if things go wrong.)
Bear in mind though that database rebuild takes a long time. Don't assume that it's crashed unless you've waited for it a good fifteen minutes.
#154492 - 09/04/2003 13:10 Re: Dead EMPEG!!! Help! [Re: sirmanson]
jaharkes
FAQ ?
#154493 - 09/04/2003 13:41 Re: Dead EMPEG!!! Help! [Re: peter]
sirmanson
Loc: Tucson, AZ USA
I will throw on a copy of 2.0 final when I get home tonight as well as going through the steps for a possible bad track (FAQ entry noted) .. Thanks
----- RioCar 60gb
#154494 - 09/04/2003 14:03 Re: Dead EMPEG!!! Help! [Re: sirmanson]
As well as the FAQ entry right next to it about removing the database files and synching...
#154495 - 10/04/2003 17:17 Re: Dead EMPEG!!! Help! [Re: tfabris]
sirmanson
Loc: Tucson, AZ USA
Upgrading to 2.0 final did the trick. I guess I got lucky that I hadn't done that yet. Thanks for the help guys
----- RioCar 60gb
#154496 - 14/04/2003 17:05 Re: Dead EMPEG!!! Help! [Re: tfabris]
sirmanson
Loc: Tucson, AZ USA
Ok, Jemplode seems to have bit it again. I was in the middle of backing up all of my songs and the player locked. I rebooted it and nothing. So I hooked up the serial cable and here is what it is showing in hyperterminal ---
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-230, ATA DISK
hdb: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:0
0
Partition check:
hdb:hdb: irq timeout: status=0xd0
ide0: reset timed-out, status=0xd4
hdb: status timeout: status=0xd0
hdb: drive not ready for command
end_request: I/O error, dev 03:40 (hdb), sector 0
unable to read partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
It looks like it is having hard drive problems. It is no longer under warranty. Should I go ahead and start checking for loose cables and/or bad solder points as described in the FAQ or does it look like something else is wrong??
TIA!!
----- RioCar 60gb
#154497 - 14/04/2003 17:32 Re: Dead EMPEG!!! Help! [Re: sirmanson]
sirmanson
Loc: Tucson, AZ USA
Ok, I just found the portion of the FAQ that talks about "Probing Primary Interface" problems. I went ahead and started pulling the Empeg apart to check the cables/ide solder points. I cannot get the shock mount cradle out. All four of the screws on the outside of the case are in WAY too tight and I don't want to strip them.
Does anyone have any tips??
----- RioCar 60gb
#154498 - 14/04/2003 17:46 Re: Dead EMPEG!!! Help! [Re: sirmanson]
"Probing Primary Interface" is a normal thing for it to say. Note how it detects the drive right after that. I think it's supposed to look like that.
#154499 - 14/04/2003 17:51 Re: Dead EMPEG!!! Help! [Re: sirmanson]
Hm. Probably the loctite. Using the correct-sized screwdriver head helps, by the way. One of those large-handled screwdrivers with an interchangeable head is often the best way to get those undone. If you use a small "jeweler's" screwdriver set, you might not be able to get enough leverage to undo them.
#154500 - 14/04/2003 17:56 Re: Dead EMPEG!!! Help! [Re: tfabris]
I take that back. Your "Probing Primary Interface" only shows HDB which is the second disk drive. It's not seeing HDA, the first disk drive, so yeah, that's the root of your problem: Disk trouble. Here's what my boot log looks like...
hda: FUJITSU MHS2040AT, ATA DISK drive
hdb: IBM-DJSA-210, ATA DISK drive
hda: FUJITSU MHS2040AT, 38154MB w/2048kB Cache, CHS=4864/255/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
So yeah, you got disk trouble and should be replacing the cable and checking the IDE header.
#154501 - 14/04/2003 20:50 Re: Dead EMPEG!!! Help! [Re: tfabris]
Not to mention that hdb is not showing up as heathy.. definitely a hardware issue there.
#154502 - 15/04/2003 07:59 Re: Dead EMPEG!!! Help! [Re: tfabris]
sirmanson
Loc: Tucson, AZ USA
I'll head to the hardware store for one of the screwdrivers you suggested then. Thanks!
----- RioCar 60gb
