#174045 - 06/08/2003 15:01
I love Sweden
Any place that allows this has to be one pretty cool place to live (pun intended, given the current Euro heatware).
#174046 - 06/08/2003 15:13
Re: I love Sweden
[Re: schofiel]
He asked his boss whether he could wear shorts for comfort as temperatures hit 25C (77F). Oh, boo-hoo! Poor guy, 77 degrees! How sweltering hot! Such torture!!
#174047 - 06/08/2003 16:41
Re: I love Sweden
"The Scottish are very lucky to be able to wear kilts all the time," he said Yup. Nothing quite as cooling as layers of heavy wool.
#174048 - 06/08/2003 21:54
Re: I love Sweden
Well, that is the outside shade temp. Inside that big piece of glass with the sun beating down on it and no AC it gets a lot hotter than 25C/77F...
/Michael - Swede...
#174049 - 06/08/2003 22:10
Re: I love Sweden
[Re: mtempsch]
Good point, I think some of the guys in the US are probably not aware that most buses and similar vehicles in Northern Europe don't have AC. We are just not used to these type of temperatures.
It nearly reached 100 degrees F here in the UK yesterday and it has been the major news story for the last three days (since they forecasted we would beat the UK record and cross the 100 degree mark). In the end we didn't cross the 100 degree F mark, so the UK record stood. London did have it's hottest day in recorded history though.
On a related point the last couple of days have been a good test for my "server room" (the roof space above my garage). While it got hot in there yesterday it stayed cooler than the outside temperature and cooler than my office used to get with the servers in there.
http://dipsy.norman.cx/mrtg/temp.html
My server room peaked at 34 degrees C, my office used to get closer to 40 degrees C. I know these still aren't ideal temperatures for PCs, but without AC it is the best I can do. At least most of the rest of the year they spend their time at 10 degrees C...
#174050 - 06/08/2003 22:54
Re: I love Sweden
[Re: schofiel]
Loc: Germany
what about a build in fan?
we did it with the empeg!!!
#174051 - 07/08/2003 01:56
Re: I love Sweden
[Re: andy]
In the end we didn't cross the 100 degree F mark, so the UK record stood. It's a shame the Cambridge AT&T automatic weather centre isn't an official Met Office one. For much of yesterday afternoon it was reading 38.3C (101F). It's never previously read more than 35C.
#174052 - 07/08/2003 02:53
Re: I love Sweden
[Re: andy]
Andy,
What hardware are you using to get the temperature data? Did you write the software that records it? Care to share it?
Jim
#174053 - 07/08/2003 06:12
Re: I love Sweden
[Re: mtempsch]
I'd kill for summer temps of 77. It gets so humid in the DC area that it hurts to breathe outside, especially combined with 95+ degree temps (and all the car exhaust). And I'm sure there are other places that are worse.
Now, at that 100 degree mark, then you have my sympathy. I feel for you there. But at 77, no way. I always open my car windows at anything between 65 and 85.
It's odd, because this seems to be a fairly cool summer in DC (only relatively), but apparently you guys are having a heatwave. Meanwhile it's hard to find a day over here that isn't overcast, gloomy, humid, and just plain gross. Not sure what it is about this summer. This morning is fairly nice. It's 78 degrees and with only 87% humidity
#174054 - 07/08/2003 06:16
Re: I love Sweden
Loc: Texas
That's what I thought... besides assuming and hoping the dash of his bus was above waist high.
Our forecast for the next 2 days:
Today
Sunny and hot. Highs near 105. Light winds.
Tonight
Clear. Lows in the mid 70s. Light winds.
Friday
Mostly sunny. Highs near 105. East winds 5 to 10 mph.
8/2 101
8/3 101
8/4 103
8/5 95
8/6 104
#174055 - 07/08/2003 12:09
Re: I love Sweden
[Re: TigerJimmy]
The hardware is the kit from this page:
http://www.qkits.com/serv/qkits/diy/pages/QK145.asp
It is very quick and easy to build and plugs straight into the serial port. I had mine built and taking readings in about an hour and I'm hopeless with a soldering iron.
Reading values from it is very easy, just read from the serial port and you get:
R V1.0 2001-10-13 11:56:11 C
1 0026.75
The first line is just a version number of the eeprom code. You then get one line for each sensor (I only have one plugged in at the moment).
I have the following (very) simple shell script to read a single reading:
#!/bin/bash
echo `head -n 3 /dev/ttyS0 | tail -n 1`
I use MRTG to plot the graph. Unfortunately MRTG only knows about whole numbers so I have to times the temperature reading by 100 and plot that. The script that I point MRTG at looks like this:
echo "`/usr/local/bin/tempread |cut -c 5-9` * 100" | bc | sed s/.00$//
echo "0"
echo "0"
echo "0"
Probably horrible, but I'm no shell script expert...
Finally, the chunk from my MRTG config file looks like this:
Target[temp]: `/usr/local/bin/tempmrtg`
MaxBytes[temp]: 4000
Factor[temp]: 0.01
Options[temp]: gauge, nopercent, noo, transparent
XSize[temp]: 600
YSize[temp]: 150
YLegend[temp]: Temp
ShortLegend[temp]: C
LegendO[temp]: Nowt:
LegendI[temp]: Temp C:
Title[temp]: Server room temp
PageTop[temp]: <H1>Server room Temperature
</H1>
<TABLE>
<TR><TD>System:</TD><TD>Server room temp</TD></TR>
</TABLE>
I must get round to connecting the other sensors, one for outside temperature and the other two for inside my two servers.
P.S. I should be using RRDTool instead of MRTG as it knows about fractional numbers and does better graphs. Whenever I look at it I can't work it out though. I think I'm getting old and stuck in my ways...
#174057 - 09/08/2003 11:00
Re: I love Sweden
[Re: andy]
Cool. What a fun toy. Thanks for the info, Andy. I think I'll pick one of those up.
Jim
#174059 - 09/08/2003 11:49
Re: I love Sweden
[Re: julf]
Loc: New Orleans, LA
Hmmmm... That's pretty cool. Not too terribly expensive to boot.
#174060 - 09/08/2003 12:58
Re: I love Sweden
[Re: julf]
They have some buyer affinity program, did you buy from them and want to have referred me if I buy?
#174061 - 09/08/2003 13:13
Re: I love Sweden
[Re: schofiel]
Loc: Yorkshire UK
Of course, none of all this would be cause for comment in the Solomon Isles.
#174062 - 09/08/2003 19:05
Re: I love Sweden
[Re: Daria]
Actually, not yet, but go ahead and post your ID, or PM it to me so that when the funds are available I'll be able to use it. I am definitely interested in getting one, just terribly broke at the moment.
Oh wait, nevermind... I just reread your post and got it backwards.... Well, the offer is now extended to you. Whoever buys it first can "recommend" the other.
Edited by lectric (09/08/2003 19:07)
#174063 - 10/08/2003 07:13
Re: I love Sweden
[Re: andy]
Well, after the longest run of really hot days that I can ever remember in the UK, we finally crossed the 99F mark today. It looks like we'll probably make 100F by the end of the afternoon somewhere.
http://news.bbc.co.uk/1/hi/uk/3138865.stm
I'm just praying for some cooler weather though, I really can't cope with these sorts of temperatures for more than a day or two.
Edited by andy (10/08/2003 07:18)
#174064 - 10/08/2003 07:52
Re: I love Sweden
[Re: andy]
Wow, I really think we must have traded weather this summer with you guys. We've had no really hot days this year (still really humid), and we've had more rain and gloomy days than I can remember.
#174065 - 10/08/2003 15:25
Re: I love Sweden
We made it - hottest day ever in the UK (well, since records began in 1875).
I spent most of the day rewiring gadgets inside a car. A very hot car.
#174066 - 10/08/2003 20:20
Re: I love Sweden
[Re: rob]
At Bournemouth in Dorset, the coastline was crammed to capacity with about 100,000 sun lovers and "no spare sand".
That's sand? Looks more like rocks from that pic. This is more what I'm used to.
#174067 - 10/08/2003 21:59
Re: I love Sweden
[Re: lectric]
Brighton beach was crowded and chaotic
Pebbles.
#174068 - 11/08/2003 00:54
Re: I love Sweden
[Re: lectric]
Not only that, but from the photo, their idea of "no spare sand" is ten feet between beach towels. On certain California beaches, "no spare sand" is ten millimeters betwen beach towels.
The caption said "crowded and chaotic", but to me, that looks like a slow day for some of the beaches I've been to.
![](http://newsimg.bbc.co.uk/media/images/39385000/jpg/_39385455_brighton.jpg)
#174069 - 11/08/2003 01:01
Re: I love Sweden
You must know by now us Brits don't like getting too close to strangers, or talking to people on the train/bus, or queue jumpers, or hot weather, or cold weather...
#174070 - 11/08/2003 01:12
Re: I love Sweden
[Re: andy]
I know you're just kidding, but I wanted it on record that all the people we met during our time in London and Cambridge were friendly and nice. I didn't get those antisocial impressions at all.
#174071 - 11/08/2003 01:22
Re: I love Sweden
Oddly though I'm not really kidding about much of that stuff. Yes we are mostly friendly, but there are certain rules that have to be observed...
I missed one important thing off of the list; we don't complain about bad customer service (which probably explains the lack of customer service we have in the first place).
#174072 - 11/08/2003 01:34
Re: I love Sweden
[Re: lectric]
Yeah Bournemouth has a proper beach, the photo was of Brighton which is pebbles. Brighton makes up for this with the best night life in the south east. Besides, who wants to get sand in their clothes?
#174073 - 11/08/2003 01:35
Re: I love Sweden
[Re: rob]
Loc: Yorkshire UK
I for my part repaired the bed, which has been propped up on a heap of "Railway Modeller's" these last few months and decided that it would be a good day to finally load up all my wife's CD's for the Rio Receiver, wot I won at the meet, - after all, it keeps you away from people.
We decided that it would be a real space saver in the kitchen .
My wife picks up "best of" albums at Sainsbury's checkout, when she's shopping. Statistics:
7 copies of a whiter shade of pale on different CD's
3 Cd's repeated, same content, different names, different record labels.
Yes, we have Terry Jacks
Rio-Receiver recognises Abba and the BeeGees as albums, but not as artists - is this a matter of taste or a glitch in the software? I may post in the appropriate place, later.
The music stops when the microwave starts, I've got a wireless network.
#174074 - 11/08/2003 02:18
Re: I love Sweden
[Re: rob]
Got to love Bedford during this hot weather. Or more specifically wearing full racing overalls and a helmet, being strapped into a small compartment attached to a very hot thing and driving very fast round black tarmac at Bedford Autodrome.
Whoooohooo - what a day! Got to drive the Caterham 7, Evo VI, Vauxhall VX220 turbo, Jaguar JP1, Renaultsport Clio, go-karts, offroady things and a (slightly) restricted Formula Palmer Audi single seater!
I have never got so dehydrated in my life, although I was drinking stacks of water at every break. Some of those cars are just toasty, though - the Caterhams, especially, with their wonderful foot-warming thin aluminium bulkheads.
I never realised how good the VX220 was. Calling it a Vauxhall gives you the wrong impression. It should be called a Lotus
