Page 9 of 14 < 1 2 ... 7 8 9 10 11 13 14 >
#196526 - 22/05/2004 17:00 Re: Success [Re: maczrool]
genixia
I'm confused about seeing the two lines in the boot log.
The memory report following is correct for 32MB though - the first line reports in bytes, the following lines in kB. If you divide 31928320 by 1024 you get 31880. The low 'free' memory count is because linux uses an aggressive caching strategy and does not discard old data immediately upon the premise that it may be needed again soon. Read here for an overview of linux page caching.
#196527 - 24/05/2004 14:14 Re: Success [Re: maczrool]
Post the boot log, in its entirety, please.
#196528 - 24/05/2004 21:25 Re: Success [Re: mlord]
maczrool
Loc: Louisiana, USA
Here's a really dumb question. How do you get hyperterminal to copy in Windows XP? Sometimes it will and sometimes it won't. Right now it's not. I've selected all and hit control+c as well as selecting copy in the menu, but there is nothing to paste, even with a screen full of boot log! My only solution has been to be to a W2K computer.
Anyway, here it is:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 ([email protected]) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 9, serial number 40104008)
Command line: mem=16m temp=N90
Memory: 15064k/16M available (960k code, 20k reserved, 332k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004500).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:a
8
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initEXT2-fs: ide0(3,4): couldn't mount because
of unsupported optional features.
empeg-car 1.03.
3bb31168 DHCP Our mac is 00:02:d7:28:0f:a8
3bb31168 DHCP Our address is 255.255.255.255
3bb31168 DHCP Broadcast address is 255.255.255.255
3bb31168 DHCP Current IP address is 255.255.255.255
3bb31168 DHCP Sending DHCP discover
3bb31169 DHCP Sending DHCP discover
3bb3116b DHCP Sending DHCP discover
3bb3116e DHCP Sending DHCP discover
3bb31175 DHCP Sending DHCP discover
3bb31184 DHCP Sending DHCP discover
3bb311a3 DHCP Sending DHCP discover
e000 v1.03
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0004580).
8
Partition check:
empeg-car 1.03.
3bb311e5 DHCP Our mac is 00:02:d7:28:0f:a8
3bb311e5 DHCP Our address is 255.255.255.255
3bb311e5 DHCP Broadcast address is 255.255.255.255
3bb311e5 DHCP Current IP address is 255.255.255.255
3bb311e5 DHCP Sending DHCP discover
3bb311e6 DHCP Sending DHCP discover
3bb311e8 DHCP Sending DHCP discover
3bb311ed DHCP Sending DHCP discover
3bb311f8 DHCP Sending DHCP discover
3bb3120f DHCP Sending DHCP discover
3bb3123e DHCP Sending DHCP discover
Player received SIGINT, user interruption
Starting bash.
úShell exit
empeg-car 1.03.
3bb3124b DHCP Our mac is 00:02:d7:28:0f:a8
3bb3124b DHCP Our address is 255.255.255.255
3bb3124b DHCP Broadcast address is 255.255.255.255
3bb3124b DHCP Current IP address is 255.255.255.255
3bb3124b DHCP Sending DHCP discover
3bb3124c DHCP Sending DHCP discover
3bb3124f DHCP Sending DHCP discover
3bb31256 DHCP Sending DHCP discover
3bb31263 DHCP Sending DHCP discover
3bb3127e DHCP Sending DHCP discover
3bb312b4 DHCP Sending DHCP discover
e000 v1.04
Copying kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg state support initialised 0089/88c1 (save to d0004980).
8
Partition check:
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
! tags.cpp : 61:Failed to open tags (0xc0041014).
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004d00).
8
Partition check:
ta13 2002/07/24.
^T^T^TProlux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
0000 empeg-car (issue9) board test version 0.05 <[email protected]>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id FUJITSU MHL2300AT
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v391 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed May 12 16:43:07 EDT 2004
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30102420)
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
TCP: Hash tables configured (ehash 32768 bhash 32768)
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0005500).
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:7
4
Partition check:
Timezone: /usr/share/zoneinfo
Freeing unused kernel memory: 4k initTimezone: /usr/share/zoneinfo/Atlantic/Azor
es
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#196529 - 24/05/2004 21:45 Re: Success [Re: maczrool]
genixia
I don't know why you've got so many boot logs there (what's the story??) but the last one looks good as far as I can tell:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
The c2000000 'failure' is where the kernel is trying to test beyond 32MB.
#196530 - 24/05/2004 23:18 Re: Success [Re: genixia]
Because Hyperterminal on Windows saves a certain amount of scrollback as part of the .ht file. I don't think there's actually a way to clear the scrollback in hyperterminal other than to delete the .ht file and start over again. Yeah, I know it sucks.
#196531 - 25/05/2004 01:52 Re: Success [Re: pgrzelak]
One thing I have notice and it's probably also due to the extra inherent disk caching built in to Linux the Mark mentioned.
Before the RAM upgrade with 3.0a7 I would get frequent short music pauses when entering the playlists menu (I think the disk was spinning up) or each time I'd type a letter in the search function. This is completely gone now probably due to the empeg not having to access the disk quite as much.
BTW: Could an admin delete my image please - I can't edit the post anymore. I apologise for making it so big causing everyone's browsers to stretch everything out.
#196532 - 25/05/2004 07:51 Re: Success [Re: maczrool]
Use TeraTerm instead.
Alternatively, set Hyperterminal to log to a file, and pick up the relevant data from there.
#196533 - 27/05/2004 10:00 Re: Success [Re: genixia]
Yup, looks good. I believe that Stu has a working 32MB player in hand!
The old logs in hyperterm were just confusing things.
cheers
#196534 - 27/05/2004 10:51 Re: Success [Re: mlord]
maczrool
Loc: Louisiana, USA
Thanks for the QC and of course Hijack!
Stu
#196535 - 29/05/2004 16:39 Re: Success [Re: maczrool]
Mach
Loc: Texas, USA
Woot! I'm now a member of the 32 club. Thanks Stu!
#196536 - 30/05/2004 10:55 Re: Success [Re: Mach]
Hey, welcome aboard Alvin!
I think that makes about five of us already, with many more to follow in the near future!
#196537 - 31/05/2004 10:14 Re: Success [Re: mlord]
Happy Birthday StigOE
Yep, I can report two more success stories. Both my main and backup are now at 32Mb:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
empeg:/empeg/bin# cat /proc/meminfo
total: used: free: shared: buffers: cached:
Mem: 31928320 18505728 13422592 1306624 4046848 12496896
Swap: 0 0 0
MemTotal: 31180 kB
MemFree: 13108 kB
MemShared: 1276 kB
Buffers: 3952 kB
Cached: 12204 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Thanks to Paul for the two memorysets.
Stig
#196538 - 01/06/2004 11:23 Re: Success [Re: mlord]
Folsom
Loc: Atlanta
I also successfully upgraded both of my players to 32 MB.
Also, many thanks to Paul for making the memory available!
#196539 - 01/06/2004 18:08 Re: Success [Re: Folsom]
FireFox31
Loc: East Coast, USA
I just want to chime in and say you guys are hardware hacking champions. These 32 meg upgrades are really something.
FireFox31
#196540 - 02/06/2004 14:05 Re: Success [Re: andym]
Hi Andy,
I think I'll give my Mk2a a shot over the next couple of weeks, but thought I'd get some reassurance. Did you come up against anything difficult? Aside from everything just being very small and fiddly? Is it easy to accidentally splurge (technical term) solder across adjacent pins?
I gather it is just a case of soldering the two chips on - all except pin 14 on each which gets wired to pin 123, correct?
#196541 - 02/06/2004 14:21 Re: Success [Re: frog51]
In my experience, patience, a good light, a half decent iron and possibly some magnification is all you need. Straighten the pins on the new chips (dead important), line them up on the existing ones (make sure your pin 1 spots match up). Try genexias tips for soldering the pins down, with the right amount of solder on the tip it works a treat. Keep pin 14 out of the way and wire the pin on both chips to 123.
I would look at the pictures on this thread so give you an idea of which CPU pin to use, that's the bit I like the least. I sure that if mine fails it'll be that connection.
#196542 - 02/06/2004 16:40 Re: Success [Re: frog51]
maczrool
Loc: Louisiana, USA
Yeah, be careful how you handle pin 14. It becomes stressed when it gets bent upward and even the slight stress from attaching the C/S line to it can cause it to break. This happened to us and getting at the remaining lead that is buried inside the package is not easy.
Stu
#196543 - 02/06/2004 20:11 Re: Success [Re: maczrool]
Waterman981
Loc: Salt Lake City, UT
That just happened to me last night when installing mine. Unfortunately where it broke I know I don't have the skills to repair it. So yeah, be careful on pin 14.
-Michael
#040103696 on a shelf
#196544 - 02/06/2004 21:02 Re: Success [Re: Waterman981]
maczrool
Loc: Louisiana, USA
So did it break flush with the side of the package? That's what happened when ours broke, but we just dug and dug until enough lead was exposed to attach the wire. You could try that if that's what happened. The worst part of replacing the chip rather than repairing it is removing the damaged one without disturbing the OEM ones below.
Stu
#196545 - 02/06/2004 21:45 Re: Success [Re: maczrool]
Waterman981
It did break flush. It was of course after every leg was attached. I did remove both of them after that until I can get new chips. I had no problems removing them and everything is working just like before. How did you get through the package to get to the lead?
-Michael
#196546 - 02/06/2004 22:09 Re: Success [Re: Waterman981]
maczrool
Loc: Louisiana, USA
We used a sharp X-acto blade to slowly chip away at the epoxy material until we got enough of the lead exposed. It was probably easier than desoldering the damaged chip (cheaper too).
Stu
#196547 - 03/06/2004 02:14 Re: Success [Re: andym]
Cheers. I will let you know how it goes
#196548 - 03/06/2004 16:31 Re: Success [Re: Shonky]
SE_Sport_Driver
Does anyone have any tips on pulling the main board out of the player? Will it be obvious when I start? I'm sending my player off to Mark for and IDE repair and he requested I send only the board.
#196549 - 03/06/2004 19:01 Re: Success [Re: SE_Sport_Driver]
genixia
It's fairly obvious. Just take usual anti-static precautions and don't forget to remove the hex huts from the serial port!
#196550 - 03/06/2004 21:28 Re: Success [Re: SE_Sport_Driver]
Yeah, there's a specific list of tips including some movie files in the usual place.
#196551 - 04/06/2004 04:56 Re: Success [Re: tfabris]
How badly is this complicated (if at all) by the addition of a digital out card?
#196552 - 04/06/2004 05:38 Re: Success [Re: tfabris]
SE_Sport_Driver
Wow Tony. I keep thinking I know what's in the FAQ and you always seem to have so much more than I thought! You're like a ninja sneaking around there adding content while nobody is looking!
#196553 - 04/06/2004 13:08 Re: Success [Re: tfabris]
SE_Sport_Driver
Wow, that was really easy! Hopefully, I'll be able to get the display to line up when I put it back together (I remember adjusting the height of my Mk2 way back when).
Thank you!
#196554 - 04/06/2004 13:16 Re: Success [Re: SE_Sport_Driver]
That's just some careful trial-and-error, you'll be fine.
While you've got the display off and the motherboard out, I recommend tightening and using loctite on all the screws that connect the handle, those loosen rather easily. If you've got the skills, I also recommend this. A rattling handle is annoying. My friend Tod's handle actually squeaks as it rattles and I keep telling him I'll fix it for him if only I he'd let me get my mitts on the player for long enough.
#196555 - 04/06/2004 16:39 Re: Success [Re: pgrzelak]
genixia
Your .sig is out of date.
