#222044 - 20/08/2002 19:42 stupid rioplay question
jbrese
Gosh I feel stupid, but I have looked and can't figure it out!
How do I at streams to the streams.cfg file that is embedded in the rioplay reciver.arf file?
I tried going at it with Notepad.exe, but that scrozzed it good...
What's the right way to edit the streams.cfg file so that it downloads to the RIO?
Many thanks...
Jim
#222045 - 20/08/2002 20:33 Re: stupid rioplay question [Re: jbrese]
ineedcolor
Loc: Windsor, Ontario Canada
I asked this very same question a number of times...It still hasn't been aswered to the point where I can get it done so now I just don't use Rioplay anymore....
#222046 - 20/08/2002 21:35 Re: stupid rioplay question [Re: jbrese]
dave
Loc: San Diego, CA
OK, for starters, take a look at this post for instructions on how to extract the file and place it back in the receiver.arf (if you haven't gotten that far yet). When you say you edited it with Notepad, I assume it came up all garbled, right? Try editing it with Wordpad which can handle Unix style text files correctly. Otherwise I'm also attaching a Windows style streams.cfg file to this post that you can download which you can modify with Notepad and insert into the receiver.arf file. Rioplay can deal with both Windows and Unix style text files so that shouldn't be a problem.
The format is pretty lame really: A line that contains <title> followed by the title of the stream and then 1 or more lines containing URLs for that stream. You should probably make sure there's no extra blank lines at the beginning or end of the file as the parser isn't very robust.
2260-streams.cfg (254 downloads)
#222047 - 21/08/2002 10:04 Re: stupid rioplay question [Re: dave]
jbrese
Thanks.
I missed the part about the arf file being a tar file. Makes much more sense. I'll sick my 15 year old on the project and see if he can make it work with your pointer.
Many thanks,
Jim
