Page 1 of 5 1 2 3 4 5 >
#227333 - 16/07/2004 10:11 Memory boards
Hi.
OK. Here's the deal. I have a design for a memory upgrade board for Mk2/2A boards which (although I haven't yet built a prototype) I'm pretty sure will work quite nicely. After much thought, I was unable to come up with a good way of getting it above 64MB, but that should be sufficient for most people. I had hoped for 128MB, but it turns out to be pretty much undoable.
It would be possible to add other things as well, but after talking it over with Hugo we decided there wasn't all that much point. I had considered both 100mbit ethernet and USB host, but dumped them for various reasons:
1) the data rate from the USB host controllers suitable for use in this application are dreadful, according to Hugo, and the controllers consume enormous amount of idle bus cycles, thereby slowing things down.
2) for a number of reasons that have been thoroughly explored in past discussions, 100Mbit ethernet in this application wouldn't really achieve much that 10Mbit doesn't, and complicates things quite a lot.
3) There are supply problems with some of the parts for both USB and ethernet
4) It may well not fit anyway.
So, the current plan is for a PCB which will fit to the underside of the main board, attaching to the test points. It will have 8 64Mbit DRAM chips giving a total of 64MB of ram, and will require one patch wire. On a MK2A you could omit the wire and still get 48MB. On a MK2 you will have to remove the chips currently fitted to get the full amount.
It is a completely surface mount device, and would as such not really be suitable for selling as a kit. I will therefore have to get the things made in batches as completed sub-assemblies, which will then need to be fitted by one or other of the prople floating around who are good at such things.
I am provisionally aiming at a price of about £90-100, and the advantage of doing it this way should be shorter lead times and less supply problems than the tuner kits have. So far, I have contacted a company who can do the assembly, have routed the PCB, and I'm waiting for a quote on quantities of the RAM and on manufacture of the boards.
Anyone interested?
Pca
#227334 - 16/07/2004 10:26 Re: Memory boards [Re: pca]
I'll take one!
Note about 100mb/s ethernet: with more memory, the underlying assumptions have changed, and it would now be able to have a more noticeable impact on I/O due to Linux's caching (which now has more memory to play with).
#227335 - 16/07/2004 10:33 Re: Memory boards [Re: pca]
skibum
Loc: Swindon, UK
Drooooool.
I'll take 2 please Patrick. And someone to install them
#227336 - 16/07/2004 10:42 Re: Memory boards [Re: pca]
Yep, I'll take one.
Do you still have to remove the original chips for a Mk2a? I assume yes but you only mention that it's necessary for the Mk2 in your post. If not, the original chips are redundant, right?
And there is enough room underneath the PCB right? I don't remember huge amounts of space between the board and metal case but we are talking only one surface mount chip thickness plus PCB (~3mm?)
#227337 - 16/07/2004 10:46 Re: Memory boards [Re: skibum]
I am, of course, interested. Four, please. But, a question: what does this do to people with enhanced memory via the stacking method? Does all of the memory need to be removed?
#227338 - 16/07/2004 10:52 Re: Memory boards [Re: pca]
I'll take two.
#227339 - 16/07/2004 10:53 Re: Memory boards [Re: Shonky]
The board adds 4 identical banks of 16MB, and duplicates the bank0 set currently present on a MK2A. Obviously, this isn't going to work all that well. The idea is that each bank can be disabled by means of a switch on the memory board, so in the case of a MK2A you would turn off the first bank. This would still give you 64M, as the original memory would be used.
As for room, there's a whole 2.5-3mm available! 0.8mm for the PCB, 1.2mm for the chips, 0.1mm for the insulator sheet on each side of the PCB, and loads of room left over
#227340 - 16/07/2004 10:55 Re: Memory boards [Re: pgrzelak]
Well, if you've already butchered your poor board, you could disable the appropriate banks on the expansion board to compensate. I would recommend removing the added stacked chips, but it shouldn't be absolutely necessary. You would still only have 64MB though.
#227341 - 16/07/2004 11:01 Re: Memory boards [Re: pca]
Ah, my board has been hacked a few times already - digital out, illumination hack. The memory was just the most recent. Still, if it is a matter of only gaining an extra 16MB over the existing 48, it may not be practical. Still, I would like to get the boards anyway, just in case I run into trouble later on.
#227342 - 16/07/2004 11:12 Re: Memory boards [Re: pca]
crazymelki
Loc: Switzerland
I'll also take two.
crazymelki.com
#227343 - 16/07/2004 11:19 Re: Memory boards [Re: pca]
Major_Sarcasm
Loc: Isle of Wight, UK
I'll take one, please Sir.
Steve
#227344 - 16/07/2004 11:23 Re: Memory boards [Re: pca]
robricc
I'm probably in for two or three at least.
#227345 - 16/07/2004 11:33 Re: Memory boards [Re: pca]
Folsom
Loc: Atlanta
I'll take two of the boards.
#227346 - 16/07/2004 11:51 Re: Memory boards [Re: pca]
BryanR
Loc: Berkshire, UK
I'll take one as well, thanks!
Bryan.
#227347 - 16/07/2004 11:58 Re: Memory boards [Re: pca]
Attack
Loc: Florida
I would order two
#227348 - 16/07/2004 12:11 Re: Memory boards [Re: pca]
Mach
Loc: Texas, USA
I'm in for 1, maybe 2.
#227349 - 16/07/2004 12:20 Re: Memory boards [Re: pca]
BAKup
Loc: Houston, TX
Count me in for 2.
--Ben
78GB MkIIa, Dead tuner.
#227350 - 16/07/2004 12:31 Re: Memory boards [Re: BAKup]
OK, so it looks like my initial test batch of 25 is gone already! I may have to do a bigger initial set.
I have heard back from the memory supplier, and the chips are in stock and rather cheaper than I feared. So that's all right then.
Just the PCB to go now.
#227351 - 16/07/2004 12:33 Re: Memory boards [Re: pca]
mvigneau
Loc: Manchester, NH
I'll take one. I will have the person that repaired my other chips (many times) do the surface mount soldering for me.
#227352 - 16/07/2004 12:41 Re: Memory boards [Re: pca]
peakmop
Loc: 384400 km from the Moon
It really sounds much better than stacking and having 6->3 patch wires dangling around.
Count me in for one of those.
#227353 - 16/07/2004 12:52 Re: Memory boards [Re: pca]
SuperQ
Loc: Berlin, DE
I'm very much interested, I have an original MK2 player.
80gig red mk2 -- 080000125
#227354 - 16/07/2004 13:34 Re: Memory boards [Re: pca]
Chuck
I'll take at least two!
#227355 - 16/07/2004 13:35 Re: Memory boards [Re: pca]
coolblue
Loc: Switzerland
count me in for two
#227356 - 16/07/2004 13:37 Re: Memory boards [Re: Chuck]
Hmm, a hundred quid for another 32MB of memory. Takes me back ten years! For that sort of price I would struggle to justify it to myself... (Says the man who's just dropped £100 on new headphones )
#227357 - 16/07/2004 14:14 Re: Memory boards [Re: pca]
gogee2000
count me in for one as well, thank you :-)
i've got a MK2 in case you need to know that as well.
greg
Edited by gogee2000 (16/07/2004 14:15)
#227358 - 16/07/2004 14:23 Re: Memory boards [Re: pca]
DBALKUNJR
Count me in for one as well.
Dave
MK2 12Gb
MK2a 60Gb
#227359 - 16/07/2004 14:29 Re: Memory boards [Re: pca]
genixia
Hey! I'd hardly call it 'butchered'.
#227360 - 16/07/2004 14:51 Re: Memory boards [Re: pca]
Happy Birthday schofiel
Need you ask? I'll take two, and I'm prepared to install/test them also.
#227361 - 16/07/2004 14:54 Re: Memory boards [Re: genixia]
You have to know Patrick....
#227362 - 16/07/2004 14:58 Re: Memory boards [Re: schofiel]
genixia
I guess he's protective of his babies. I wonder how he'll feel when I completely disassemble a Mk1 mainboard.
