#246405 - 12/01/2005 13:39 More Linux trouble
I'm trying to install a third-party VPN client on a Linux system and I'm having a problem. Hopefully one of you kernel gurus out there can help me figure it out.
There's a kernel module integral to the system, but when I try to insert it, I get the error "unresolved symbol nf_register_hook". The obvious response to this is "Build Packet Filtering into your kernel, you ninny," but I have. The system.map claims that it's in there, but don't know any way to actually verify it. I did change the version string just to make sure I was booting the right kernel, and I was. In building the kernel, I made clean, dep, clean, bzImage, modules, and modules_install and then put .../arch/i386/boot/bzImage in the right place. I don't see what I'm doing wrong. Maybe I need some kernel option turned on other than just CONFIG_NETFILTER.
This is on a Gentoo 2.4.26.
#246406 - 12/01/2005 14:02 Re: More Linux trouble [Re: wfaulk]
grep nf_register_hook /proc/ksyms
Edited by mlord (12/01/2005 14:02)
#246407 - 12/01/2005 14:05 Re: More Linux trouble [Re: mlord]
c0324760 nf_register_hook_R__ver_nf_register_hook
#246408 - 12/01/2005 14:06 Re: More Linux trouble [Re: wfaulk]
It's there.
I take it you have a vendor binary kernel module for the vpn ? Matching pre-compiled modules against kernels is nearly impossible in Linux.
#246409 - 12/01/2005 14:07 Re: More Linux trouble [Re: mlord]
It's part source, part binary. The nf_register_hook thing appears to exist solely in the source part.
#246410 - 12/01/2005 14:10 Re: More Linux trouble [Re: wfaulk]
Well, the mucky bit is in how "modules" is configured in the kernel, then.
It SHOULD be as follows in /usr/src/linux*/.config
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
#246411 - 12/01/2005 14:12 Re: More Linux trouble [Re: mlord]
That's the way it is.
#246412 - 12/01/2005 16:00 Re: More Linux trouble [Re: wfaulk]
Then you are probably not running a kernel that was built with those config options. If modversions is really on, the entry from /proc/ksyms should have a crc code appended to it, as in this one from my system running 2.4.27:
c01d9e80 nf_register_hook_R41316edc
#246413 - 12/01/2005 16:21 Re: More Linux trouble [Re: mlord]
I built it myself from that config last night. Let me doublecheck.
Nope. Definitely set that way.
I'll point out that CONFIG_NETFILTER is not a module, nor, according to menuconfig, can it be.
I'm gonna try to enable some of the netfilter-related config stuff and see if that helps. (Taking shots in the dark now.)
#246414 - 12/01/2005 17:06 Re: More Linux trouble [Re: wfaulk]
Interestingly, I cannot insmod netfilter-related modules. They give me similar unresolved symbol problems. Was there a bug in 2.4.26 or anything?
Maybe I should just redo my whole kernel config and see if I can figure out what's wrong. This is the first time I've ever had any significant kernel trouble in ten years of using Linux.
#246415 - 12/01/2005 17:16 Re: More Linux trouble [Re: wfaulk]
You'll be better off by just rebuilding the kernel again.
Do this:
cp .config /tmp/dot_config
make mrproper
cp /tmp/dot_config .config
## edit Makefile by hand and change the EXTRAVERSION line
## at the top to something unique for this build.
make oldconfig
make dep clean bzImage modules modules_install
And install the kernel ("make install" ?) whatever way you normally do.
After reboot, do "uname -r" and verify that the EXTRAVERSION tag is present.
#246416 - 12/01/2005 18:09 Re: More Linux trouble [Re: mlord]
That did it. Strange. I wonder what was left over by "make clean" that "make mrproper" fixed.
Thanks a bunch, Mark.
#246417 - 12/01/2005 20:11 Re: More Linux trouble [Re: wfaulk]
Lots of stuff doesn't get redone correctly if the .config is modified without first doing a "make mrproper" (that's "Mr. Clean" outside of Finland). The kernel make system has never really worked correctly until the 2.6.xx stream.
#246418 - 12/01/2005 20:39 Re: More Linux trouble [Re: mlord]
Well, it's the first time a "make clean" hasn't done enough for me, I think. I'll keep it in mind, though.
Although I have to move to 2.6 for my 802.11g driver.
Thanks again.
#246419 - 01/02/2005 20:22 Re: More Linux trouble [Re: wfaulk]
Okay, time to rub my Magic Genie^H^H^H^H^H^H Lord Lamp again.
I was going to write out the problem I was having, but this small thread elsewhere, the second post, at least, sums things up pretty well. Any ideas?
#246420 - 01/02/2005 20:31 Re: More Linux trouble [Re: mlord]
SuperQ
Loc: Berlin, DE
yea.. I hate that.. I always have issues with redhat's kernel source not being clean enough for some stuff... I always forget to make mrproper to get it all ready for myrinet driver compiling and stuff like that.
80gig red mk2 -- 080000125
#246421 - 02/02/2005 00:29 Re: More Linux trouble [Re: wfaulk]
MMmm... binary kernel module, eh? If you don't have source code, then the *only* way it will work is on the *exact* kernel that they used when building the module.
#246422 - 02/02/2005 14:04 Re: More Linux trouble [Re: mlord]
It worked with a variety of 2.4 kernels and claims to support 2.2, 2.4, and 2.6. It's not binary-only; it's part binary, part source.
Can maybe you clue me in on the "Could not allocate 116 bytes from system (currently using 0 bytes)" part? Seems like allocating 116 bytes shouldn't be so hard.
Edited by wfaulk (02/02/2005 14:08)
#246423 - 02/02/2005 14:36 Re: More Linux trouble [Re: wfaulk]
More likely that whatever kernel call it is using has suffered a parameter change inside the (open-source) kernel. Like expecting a 64-bit value instead of a 32-bit value, or added/removed an extra parameter or some such thing. TONS of that kind of stuff happening almost daily in the 2.6 stream.
#246424 - 02/02/2005 14:39 Re: More Linux trouble [Re: mlord]
Okay. Thanks.
