#259695 - 02/07/2005 22:00 Harman-Kardon AVR 135 Receiver Woes
ineedcolor
Loc: Windsor, Ontario Canada
Not a good day. Just took delivery of my new HK AVR135 and hooked it all up. I used my old speaker wire, which worked just fine with my Sony receiver. I fire up the HK and all of a sudden it's off again. The display shows "protect" mode and my L and R front speaker icons are flashing. After some research, I find that this may be caused by a short in my wiring or an incorrect hook up. My hook ups are fine so I assume that my wiring is bad. I go out and drop $40 for a spool of new wire. Hook everything up again and same result. There are no strands of wire bridging any connections nor backwards (+/-/-/+) connections...
Did I buy a broken receiver?
I loath the thought of repacking it and taking it back across the river...
#259696 - 02/07/2005 23:15 Re: Harman-Kardon AVR 135 Receiver Woes [Re: ineedcolor]
Got a multimeter? Disconnect both ends of each cable and check for continuity between the + and - wires, there shouldn't be any. Reconnect the speakers and check again, you should see a few ohms resistance but definitely not a short. If your cables and speakers are okay, then your amp's buggered
#259697 - 03/07/2005 01:09 Re: Harman-Kardon AVR 135 Receiver Woes [Re: andym]
ineedcolor
Thanks Andy for your reply...and I'm wearing clown shoes tonight.
After much hair pulling and frustration...I think the mystery is solved. My PSB Alpha Series LR are rated at 6 ohms impedance. I just assumed that ALL modern speakers were rated at 8 ohms. Therefore they must be incompatable with the HK as all of the HK outputs are rated at 8 ohms. Funny, my cheap ass Sony receiver never had any issue with them. Guess I should have done my homework before laying down the bux for the new receiver eh?
Time to start saving for new speakers
#259698 - 03/07/2005 06:46 Re: Harman-Kardon AVR 135 Receiver Woes [Re: ineedcolor]
Happy Birthday StigOE
I think that your amp should still work with your speakers. The impedance isn't the same over the whole frequency spectrum. 6 or 8 ohms are only nominal...
Stig
#259699 - 03/07/2005 12:25 Re: Harman-Kardon AVR 135 Receiver Woes [Re: ineedcolor]
Ezekiel
Loc: NH USA
Strange. Most receivers will work with 4 or 8 ohm impedences, but not this one. From the owner's manual:
Power per Individual Channel
Front L&R channels:
40 Watts per channel
@ <0.07% THD, 20Hz–20kHz into 8 ohms
Center channel:
40 Watts @ <0.07% THD, 20Hz–20kHz into 8 ohms
Surround (L & R Side, Back) channels:
So there you go. Bummer.
-Zeke
WWFSMD?
#259700 - 03/07/2005 12:49 Re: Harman-Kardon AVR 135 Receiver Woes [Re: Ezekiel]
How strange...
#259701 - 03/07/2005 13:12 Re: Harman-Kardon AVR 135 Receiver Woes [Re: andym]
I bet it thinks something's shorted.
Try throwing a 2 Ohm resistor in line. That'll work. And it'll make your speakers sound really good, too.
(Please note that this is a joke. I don't want to be blamed when you fry your speakers and/or new amp.)
#259702 - 03/07/2005 16:13 Re: Harman-Kardon AVR 135 Receiver Woes [Re: wfaulk]
ineedcolor
Thanks Bitt, but I would never consider doing something like that (even though that was someone else's suggestion too)
Based on advice I received on another forum, I ended up returning the receiver today as defective. Apparently there are people out there using HK receivers with off-rated speakers with no issues. I let you know how the second one works out...
Update: The new receiver works flawlessly, it was worth the trip back to Detroit after all...thanks to all who responded.
John
Edited by ineedcolor (03/07/2005 17:10)
