#26351 - 07/02/2001 15:17 InfoTex OTT and 'l'
amold
I noticed a strange bug with the infotex OTT visual (Or one of the infotex ones anyway). If the artist name ends in an l, it's converted to 't' on display. The static info on the track is fine, so it's just that particular infotex mode.
Examples: Tool or Treponem Pal.
known bug ?
#26352 - 07/02/2001 15:29 Re: InfoTex OTT and 'l' [Re: amold]
You wouldn't happen to be confusing the lower case L followed by a colon with a letter t, would you? The kerning between the L and the colon is very tight...
#26353 - 07/02/2001 15:31 Re: InfoTex OTT and 'l' [Re: tfabris]
amold
you're probably right ! looks weird, though. can it be fixed to put a shade more space in between the two ?
#26354 - 07/02/2001 15:32 Re: InfoTex OTT and 'l' [Re: amold]
You could fix it yourself by adding a space to the end of the artist name in those cases...
