#292630 - 23/01/2007 03:17 Please help with 'No hd found...' error
Ladmo
Loc: Oklahoma
I have been trying and trying to get an old mk2 player to boot up, and keep getting the infamous 'No hard disk found...' error. I have checked the faq and threads, and have checked the header cable and other items that I have found, with no luck so far.
So I figured to start from square one (again), and 'hypertermed' into the unit (with the serial cable) and here is what came up
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v464 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Oct 27 01:00:29 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101787) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0004f00).
empeg RDS driver initialised
empeg single ch
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffdf
ide_data_test: wrote 0xffff read 0xffdf
ide_data_test: wrote 0xaaaa read 0xffdf
ide_data_test: wrote 0x5555 read 0x7f55
ide_data_test: wrote 0xaaaa read 0xff8a
ide_data_test: wrote 0x5555 read 0x7d55
ide_data_test: wrote 0x5555 read 0xffdf
ide_data_test: wrote 0xaaaa read 0xfb8a
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
I am hoping that someone with more smarts than I (after all, I AM a conservative!) can take a look at the above, and tell me if it looks normal or does something obvious jump out. I am really about at my 'wit's end' ... Any help would be greatly appreciated!!!!!
Ladmo
#292631 - 23/01/2007 03:39 Re: Please help with 'No hd found...' error [Re: Ladmo]
maczrool
Loc: Louisiana, USA
It looks like you probably have a fried ethernet chip. It's got a stuck bit or two. I've not been too good at interpretting the IDE tests, but at least D5 looks stuck low. You will need to cut the line or lift the pin to this or replace the chip.
Stu
#292632 - 23/01/2007 15:40 Re: Please help with 'No hd found...' error [Re: maczrool]
Also, the line "Could not find CS4231A" doesn't make things look particularly happy.
#292633 - 23/01/2007 17:04 Re: Please help with 'No hd found...' error [Re: tfabris]
maczrool
Loc: Louisiana, USA
The CS4231A seems to always get lost when the ethernet chip is bad. The IDE test pattern very much suggests a failure of the ethernet chip and not the CS4231A.
Stu
#292634 - 23/01/2007 17:15 Re: Please help with 'No hd found...' error [Re: maczrool]
Stu
Yeah, that's one tricky set of logs to intepret. I'm with Stu on this one: at least D5 is stuck, probably due to the ethernet chip (always has been in the past) having been fried.
There may also be other stuck bits, but it's hard to tell. Was there a drive (or two? connected during the capture of those logs?
#292635 - 23/01/2007 22:44 Re: Please help with 'No hd found...' error [Re: maczrool]
Ah. Gotcha. Updating the FAQ with this info.
#292636 - 24/01/2007 03:18 Re: Please help with 'No hd found...' error [Re: mlord]
Ladmo
Loc: Oklahoma
Yes, Mark, there was a drive installed. I'm not entirely sure it is good at this point....
#292637 - 24/01/2007 03:41 Re: Please help with 'No hd found...' error [Re: Ladmo]
The drive is probably fine -- you could try it in another machine if you're worried about it, but I suspect there's nothing wrong with it. The real problem here is the (very likely) fried ethernet chip, which shares the bus with the drives, USB, and other stuff.
#292638 - 24/01/2007 12:51 Re: Please help with 'No hd found...' error [Re: mlord]
For the purposes of the FAQ, would it be worth enumerating the things that share that bus?
#292639 - 24/01/2007 13:05 Re: Please help with 'No hd found...' error [Re: maczrool]
Ladmo
Loc: Oklahoma
...You will need to cut the line or lift the pin to this or replace the chip.
Thanks for all the info! Is the proceedure to cut the line or lift the pin listed or shown in the FAQ or anywhere else?
Thanks again!
#292640 - 24/01/2007 13:52 Re: Please help with 'No hd found...' error [Re: Ladmo]
Generally, one would now make arrangements to have Stu, RobS, or another like individual, accept and repair the player for you.
#292641 - 24/01/2007 18:32 Re: Please help with 'No hd found...' error [Re: mlord]
Rubbish... it sounds like an easy enough DIY repair!
#292642 - 24/01/2007 19:00 Re: Please help with 'No hd found...' error [Re: Roger]
I think that'd start crossing the line away from "information about symptoms of a frequent problem" and lean more towards "detailing the entire motherboard specifications". Useful to be posted somewhere, perhaps the empeg hardware specs section, but I wouldn't FAQ it.
#292643 - 24/01/2007 20:22 Re: Please help with 'No hd found...' error [Re: mlord]
Ladmo
Loc: Oklahoma
Yes, I am talking with Stu about arranging for him to repair it in the next couple of months. For the time being though, I wanted to at least get the player working and make sure there was no other issues with it.
Rob S. still has a player of mine that I sent him 2 Years Ago, so I wanted to talk to Stu about this ones, as it is the last one that I have besides the one that Rob S has.
So I am trying to identify which chip is the ether one....?
Thanks...Everyone here is great!!!
#292644 - 25/01/2007 03:22 Re: Please help with 'No hd found...' error [Re: Roger]
I believe it's just the IDE drives, ethernet, USB, and CS4231A chips.
#292645 - 08/02/2007 19:29 Re: Please help with 'No hd found...' error [Re: Ladmo]
Armin
Loc: New England
I think I'm having the same issue Ladmo does. This thread didn't seem to have a happy ending to it, or did I just miss that? Please, tell me there is a post coming along the lines of "and the empeg lived happily ever after"...
Armin
#292646 - 08/02/2007 20:45 Re: Please help with 'No hd found...' error [Re: Armin]
Are you sure you're having the exact same problem as ladmo, or are you having one of the usual issues?
#292647 - 09/02/2007 02:59 Re: Please help with 'No hd found...' error [Re: Armin]
Ladmo
Loc: Oklahoma
Sure there is a happy ending...I'm sending it to Stu for repair as soon as I get 'financially stable'. It is my last (only) player left, and since my other one that went out for repairs has been given up on, I don't want to risk this one any further.
#292648 - 09/02/2007 09:09 Re: Please help with 'No hd found...' error [Re: Ladmo]
Armin
Loc: New England
Tony, I checked the usual stuff, but to be sure I might try lifting a pin on the ethernet chip. It seems that bit D5 is stuck: write FFFF, read FFDF. Am I right to assume that D15 is the MSB and D0 the LSB in that notation?
Or is there any way to check ethernet without a drive installed? Hm I havent even tried that!
Ladmo: good luck! Did they tell you how much the surgery would run? I might try it myself, have some of the "proper tools" at work 8-)
Armin
#292649 - 09/02/2007 12:35 Re: Please help with 'No hd found...' error [Re: Armin]
Yes. And there's just something about D5 at the ethernet chip. It seems to always be that one particular line that gets toasted.
#292650 - 09/02/2007 13:43 Re: Please help with 'No hd found...' error [Re: mlord]
Armin
Loc: New England
So it's pin 61 I need to lift. Cross your fingers!
Armin
#292651 - 10/02/2007 10:13 Re: Please help with 'No hd found...' error [Re: Armin]
Armin
Loc: New England
Lifting the pin fixes the problem. Re-attaching it makes it come back. It's definitely bit D5 in the ethernet chip that burnt out. Looks like others had the same bit fail. Makes me wonder what's going on!
I will try to talk a coworker into replacing the chip. He's much better with fine-pitch soldering than anyone I know. Might need chocolate for a bribe...
#292652 - 18/02/2007 12:57 Re: Please help with 'No hd found...' error [Re: Armin]
Armin
Loc: New England
Well, there is a happy ending at least in my story! My friend replaced the ethernet chip and now all is well! Cost me $17 for the chip and owing a favor...
Hope your story turns out well too, Ladmo!
#325674 - 01/09/2009 19:18 Re: Please help with 'No hd found...' error [Re: Armin]
maczrool
Loc: Louisiana, USA
I've got a real headscratcher. It appears that I have a bad ethernet chip, but it is not the typical stuck D5 bit that we've seen earlier in this thread. There are several bits stuck high, but D5 appears to be working! In the past it seemed that lifting D5 would allow the other bits to get back in line, but since D5 is working, which one(s) is (are) responsible? Since only the ethernet chip and the IDE bus are 16 bits, it seems that the root cause is either one or both buffer ICs or the ethernet chip. Based on the below bootlog, is there any way to divine which bits to disable on the ethernet chip to get this working?
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
empeg-car player (hardware revision 9, serial number 30103020) 16MB DRAM
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Signature is 636f6972 'rioc'
show_message("Hijack v508 by Mark Lord")
CS4231A: not responding (00) --> no visuals for Tuner/AUX
empeg state support initialised 0089/88c1 (save to d0004900).
empeg single channel IDE
ide_data_test: wrote 0x0000 read 0xfe83
ide_data_test: wrote 0xffff read 0xfe83
ide_data_test: wrote 0xaaaa read 0xaa82
ide_data_test: wrote 0x5555 read 0x5481
ide_data_test: wrote 0x5555 read 0xd483
ide_data_test: wrote 0x0000 read 0xfe03
ide_data_test: wrote 0xffff read 0xfeff
ide_data_test: wrote 0xaaaa read 0xeaab
ide_data_test: wrote 0x5555 read 0xd455
ide_data_test: wrote 0xaaaa read 0xeaaa
ide_data_test: wrote 0x5555 read 0xfe57
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cc
RAMDISK: Loading 320 blocks [1 disk] into ram disk... | / - \ | / - \ | / - \ | / - \ | / - \ done.
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#325676 - 01/09/2009 20:05 Re: Please help with 'No hd found...' error [Re: maczrool]
Forgive me for my ignorance, but why aren't you just completely replacing the ethernet chip? Is it because you don't have a replacement?
Edit: Academic curiosity is always a valid answer for me. smile
#325677 - 01/09/2009 20:17 Re: Please help with 'No hd found...' error [Re: tfabris]
maczrool
Loc: Louisiana, USA
Good question! We've got a few of the chips, but given that it's pretty labor intensive (without a decent hot air rig) I'd rather not go that route unless that's really the problem. It could also be the level shifters which I would probably do first given the ease of replacing, but again I'd really like to narrow it down to which device is at fault.
Stu
#325681 - 01/09/2009 21:00 Re: Please help with 'No hd found...' error [Re: maczrool]
Data bus bits 8 and 15 (numbering from 0..15) are both stuck.
D8 is definitly stuck LOW ('0'), and D15 is probably stuck HIGH ("1").
Edited by mlord (01/09/2009 21:06)
#325682 - 01/09/2009 21:04 Re: Please help with 'No hd found...' error [Re: mlord]
D8 is definitely stuck LOW ('0'), and D15 is probably stuck HIGH ("1").
I say probably, because there is some contradictory evidence on D15.
So lift D8 (ethernet) first, then try again.
#325684 - 01/09/2009 21:14 Re: Please help with 'No hd found...' error [Re: mlord]
Oh.. and D5 is also stuck LOW. EDIT: mmm.. actually, maybe not.
Edited by mlord (01/09/2009 21:15)
#325685 - 01/09/2009 21:21 Re: Please help with 'No hd found...' error [Re: mlord]
One more thing to do on that unit: Apply the CS4231A fix, and see if that helps.
