Page 2 of 2 < 1 2
#325686 - 01/09/2009 21:29 Re: Please help with 'No hd found...' error [Re: maczrool]
Originally Posted By: maczrool
it's pretty labor intensive (without a decent hot air rig)
Have you ever tried ChipQuik? I haven't; I'm just curious about the experiences of those who have, and to suggest looking at it if you've never heard of it.
#325687 - 01/09/2009 23:22 Re: Please help with 'No hd found...' error [Re: wfaulk]
maczrool
Loc: Louisiana, USA
Thanks! Yes I have tried it and is what I would probably use. It's not ideal and sometimes end up losing some of the unused pads- even with the lower heat involved which I hate (from a cosmetic point of view). Overall it's not a bad solution if not a little messy and expensive. There's also the task of aligning and resoldering with a fine tip iron that followings, which with 100 pins with .5mm pitch is no fun.
Stu
#325688 - 01/09/2009 23:24 Re: Please help with 'No hd found...' error [Re: mlord]
maczrool
Loc: Louisiana, USA
Hey Mark. I knew you had a fix for the CS4231A somewhere but I just couldn't find it. I'll give all your suggestions a try tomorrow and see what happens. Thanks!
Stu
#325702 - 02/09/2009 17:41 Re: Please help with 'No hd found...' error [Re: maczrool]
maczrool
Loc: Louisiana, USA
Okay. I tried all the suggestions, but no luck. Below is bootlog after the CS4231 fix.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30103020) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
CS4231A: not responding (00) --> no visuals for Tuner/AUX
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xfe83
ide_data_test: wrote 0xffff read 0xff83
ide_data_test: wrote 0xaaaa read 0xea82
ide_data_test: wrote 0x5555 read 0x5581
ide_data_test: wrote 0x5555 read 0xd583
ide_data_test: wrote 0x0000 read 0xfe03
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xeaab
ide_data_test: wrote 0x5555 read 0x5555
ide_data_test: wrote 0x5555 read 0xd555
ide_data_test: wrote 0x0000 read 0xff03
ide_data_test: wrote 0xaaaa read 0xeaaa
ide_data_test: wrote 0x5555 read 0xff57
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cc
RAMDISK: Loading 320 blocks [1 disk] into ram disk... | / - \ | / - \ | / - \ | / - \ | / - \ done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#325703 - 02/09/2009 17:42 Re: Please help with 'No hd found...' error [Re: maczrool]
maczrool
Loc: Louisiana, USA
Here it is after lifting D8 (CS4231A fix still in place):
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0004980).
ide_data_test: wrote 0xaaaa read 0xea83
ide_data_test: wrote 0x5555 read 0xd581
smc chip id/revision 0x3249
smc_init couldn't find card
#325704 - 02/09/2009 17:44 Re: Please help with 'No hd found...' error [Re: maczrool]
maczrool
Loc: Louisiana, USA
Here it is with the CS4231A fix, D8 and D15 lifted:
e000 v1.04
Copying kernel...
ide_data_test: wrote 0x0000 read 0x7e83
ide_data_test: wrote 0x5555 read 0x5583
ide_data_test: wrote 0x0000 read 0x7e03
ide_data_test: wrote 0x5555 read 0x7f57
ide_data_test: wrote 0x5555 read 0x5557
#325705 - 02/09/2009 17:59 Re: Please help with 'No hd found...' error [Re: maczrool]
maczrool
Loc: Louisiana, USA
I'm beginning to think that the ethernet chip may have been okay. Notice that in my bootlogs up until I started lifting pins, that the ethernet chip is recognized whereas the bootlogs with the bad ethernet chips say "smc_init couldn't find card" near the end of the log. It wasn't until I disabled the pins that this couldn't find card message appeared.
Why if all 16 bits (which seem to be needed to avoid the couldn't find card message)were functional for the ethernet chip did the IDE bus not work? I've verifed that all bits of the bus are connected to the header and tried multiple drives that have been tested good.
Stu
#325709 - 02/09/2009 19:45 Re: Please help with 'No hd found...' error [Re: maczrool]
Was there a hard disk connected when you captured the above outputs? If not, then connect one, and try again. Otherwise the lines are just floating randomly.
Thanks.
#325710 - 02/09/2009 20:22 Re: Please help with 'No hd found...' error [Re: mlord]
maczrool
Loc: Louisiana, USA
Sorry. Yes there was a hard drive connected in each case.
Stu
#325711 - 03/09/2009 10:48 Re: Please help with 'No hd found...' error [Re: maczrool]
Mmm.. well, your changes earlier seem to have fixed the stuck lines. All of the bits seem capable of changing state now.
So.. I wonder if the control signals are getting to the IDE bus, or if perhaps those are now stuck high/low.
You'll have to probe them individually, I suspect, preferably with a scope or logic analyzer that can trigger on state change.
#325712 - 03/09/2009 10:52 Re: Please help with 'No hd found...' error [Re: mlord]
Mmm musing further on this, we do know that MOST of the control signals must be working, since the ethernet chip does respond, to READs at least.
Dunno about WRITEs.
#325713 - 03/09/2009 11:00 Re: Please help with 'No hd found...' error [Re: mlord]
Okay, so here's the list of IDE control signals in the empeg:
RD (read) obviously not stuck.
WR (write)
BA0,BA1,BA2 (address/register select lines)
IDECS1 (chip select)
IDECS2 (chip select)
That's mostly it. A very short list.
And since the CS4231A is also not responding,
it's most likely the pins shared with that chip.
BA0,BA1 go to both IDE and CS4231A, but not to ethernet (I think).
And the IDECS1/IDECS2 lines go only to IDE,
but they are generated by the same PEEL18CV8
that also generates the CS (Chip Select) for
the CS4231A. Perhaps the PEEL chip has died.
So.. check the lines that are in common between those
two devices (IDE, CS4231A), and see if they toggle
or are just stuck.
Edited by mlord (03/09/2009 11:05)
#325754 - 07/09/2009 19:28 Re: Please help with 'No hd found...' error [Re: mlord]
maczrool
Loc: Louisiana, USA
Thanks Mark. I haven't gotten to any logic analyzing yet, but I did notice that with the HD removed that the CS4231 appears as normal in the boot log. Simply attaching any drive to the header causes it and the boot process to fail. I wonder if it could still be a bad PEEL? We've got a bunch of them, but unfortunately they are not programmed for that application and would have to be sent out to load the applicable code.
Stu
#326156 - 17/09/2009 13:23 Re: Please help with 'No hd found...' error [Re: maczrool]
maczrool
Loc: Louisiana, USA
Now I've gotten the IDE bus to work (bad traces), but there is a problem with the I2C bus now. Which apparently configures and controls the DSP because there is no sound. Since the CS4231A fix is in place, I'm guessing the lack of a functioning DSP would kill the fix as well and explain why the CS4231A is also not working.
So it's back to probing around the PEELs and passives to the DSP to see if something has died there.
Stu
Edit: I fixed the DSP and CS4231A. For some reason, the DSP reset pin was stuck low. For whatever reason, removing the fix corrected this. I tripled checked that I had it just as Mark did and it was, but anyway all seems well now.
Edited by maczrool (17/09/2009 14:41)
Page 2 of 2 < 1 2
