#292900 - 24/03/2007 11:57
Re: We Have Lights!
[Re: julf]
Loc: Louisiana, USA
No, you haven't missed anything. I'll send payment instructions for the second batch when I finish assembling the first batch. All 10 of the first batch have been paid for, so I don't think anyone will change their mind.
Stu
#292901 - 24/03/2007 13:29
Re: We Have Lights!
[Re: maczrool]
Quote: Patrick sent us the RS-274D files, but since what we really needed were extended gerbers, I ended up extracted them myself.
Are you sure? I could have sworn I sent the RS-274X version. You should have mentioned it, it's easy to get the X variant out of ranger XL.
Quote: That Ranger app was just no fun and if I can help someone avoid using it I will
Funny, I've always thought the same about Orcad and Pads, which are much more common And MUCH MUCH more expensive. Mind you, I have been using one variant or other of Ranger since about 1988, and I've got a really huge library of tested part definitions I've produced over the years. Bear in mind all the versions of the empeg were made with ranger 2!
It would be much easier if there was some common definition langauage for exporting/importing PCB layouts and schematics between packages, but 90% of the PCB cad companies out there would cut off their own legs to avoid this happening. Might allow people to change suppliers, you see ![](/ubbthreads/images/graemlins/frown.gif)
I can use Orcad, etc, just don't like them too much. And certainly can't afford them.
Pca
#292903 - 24/03/2007 20:13
Re: We Have Lights!
[Re: maczrool]
Quote: Orcad is very expensive indeed. I believe the new version starts at about $7500? Oh well.
That is indeed expensive.
However, if you want to see ultra-crazy CAD software pricing, check out the price for single-seat licenses of IC Design software sometime.
Tools from Synopsys, Cadence, Magma, etc. tend to run over $50,000 per tool. Even HSPICE isn't too cheap.
I have a friend who has a laptop with well over $200,000 worth of IC CAD software on it!
He tends to keep an eye on that laptop.... ![](/ubbthreads/images/graemlins/laugh.gif)
I don't know anything about even more limited-demand CAD markets.
But I have to conjecture that somewhere there must be one person that designs the software used to make chemical plants or oil refineries, and that she sells two licenses per year at a gatrillion dollars apiece.
#292904 - 24/03/2007 20:38
Re: We Have Lights!
[Re: music]
But I have to conjecture that somewhere there must be one person that designs the software used to make ... oil refineries, and that she sells two licenses per year at a gatrillion dollars apiece.
Mmm.. sounds a little like what Mach does.
#292906 - 24/03/2007 23:36
Re: We Have Lights!
[Re: Shonky]
Loc: Louisiana, USA
I like the ability to make curved traces. Don't think Ranger offers that ![](/ubbthreads/images/graemlins/wink.gif) . It's funny you mentioned you were planning to engineer your own extender board. As you may have seen, I was going to do the same thing, and when I saw these schematics I noticed how overbuilt mine would have been. It would have been much more than $260 for sure. Stu
#292907 - 25/03/2007 18:25
Re: We Have Lights!
[Re: maczrool]
Loc: East Coast, USA
Here's an odd thought about 5 years too late:
Maybe the number of PCBs required could drop to one if it could do both ends of the job. Combine the features of both empeg-side and display-side boards into one, give each person two of the same board, but only populate the necessary transistors for each. Not only would it remove an entire PCB, but it would double the order quantity of the remaining PCB.
5 years too late, not worth mentioning, but interesting. Still trying to convince myself to take 2nd run spot number 10 for when I have a car without DIN... in 2014.
#292908 - 25/03/2007 18:28
Re: We Have Lights!
[Re: FireFox31]
You know what, I'll take one. The amount of money some people I know spend on things like fashion, $300 for a useful device which will last for years is pocket change. I'll take one, fully built, payment upon order.
#292909 - 25/03/2007 18:43
Re: We Have Lights!
[Re: FireFox31]
Loc: Louisiana, USA
I'll add you to the list Chris.
Stu
#292910 - 25/03/2007 18:47
Re: We Have Lights!
[Re: maczrool]
Loc: Louisiana, USA
1-thirdeyevision (2) 2-julf (1) 3-mtempsch (1) 4-andy (1) 5-matthew_k (1) 5-caseyse (1) 6-LittleBlueThing (1) 7-EtN (1) 8-juenk (1) 9-thirdeyevision's friend (1) 10-FireFox31 (1) 11-robricc (1)
We are at 13 board sets now, but that really isn't a problem since I haven't placed the order. I can place the order in any multiple of 5 sets. Also, some on the list were notified about a week ago, but have not read their PMs, so they may never come forward.
Stu
Edited by maczrool (26/03/2007 17:24)
#292911 - 26/03/2007 13:25
Re: We Have Lights!
[Re: maczrool]
One observation: A lot of the components on the receiver board seem to be related to the onboard 12V sourced PSU -- which is not actually needed or used. I wonder if there's any worthwhile cost savings to be had there?
#292912 - 26/03/2007 13:27
Re: We Have Lights!
[Re: pca]
Mine arrived first thing this morning, thanks. Looks rather fetching -- nice clean layout and all.
#292913 - 26/03/2007 13:49
Re: We Have Lights!
Loc: Louisiana, USA
Quote: A lot of the components on the receiver board seem to be related to the onboard 12V sourced PSU -- which is not actually needed or used.
I thought about that, but decided it was best to let the flexibility of a dual power supplies remain. One never knows if the need for a 100 meter run will arise at some point. The cost added is probably around $15 - $20.
Stu
#292914 - 26/03/2007 14:23
Re: We Have Lights!
[Re: maczrool]
We just need to find someone with their own 737 that needs an empeg install in the cockpit with the main unit in the tail...
#292915 - 26/03/2007 14:27
Re: We Have Lights!
[Re: maczrool]
Plus labour.
#292917 - 26/03/2007 14:46
Re: We Have Lights!
[Re: andy]
Quote: We just need to find someone with their own 737 that needs an empeg install in the cockpit with the main unit in the tail...
What, you think MarkM designed them to be capable of 100 meter runs for no reason at all? ![](/ubbthreads/images/graemlins/smile.gif)
#292918 - 26/03/2007 22:25
Re: We Have Lights!
[Re: andy]
Loc: Seattle, WA, U.S.A.
The Auxiliary Player Unit, of course.
Jim
#292919 - 27/03/2007 01:23
Re: We Have Lights!
Loc: Seattle, WA USA
I thought that I tested it for 100 feet, not meters. ![](/ubbthreads/images/graemlins/smile.gif) Patrick Arnold did the design - I was just a paper pusher on this project. I will share a little story Patrick shared with me prior to the design. He created a similar design to extend EIDE drives for long distances. He mentioned that his testing consisted of using a very old drill with a metal housing. You know, the kind where you can see sparks coming off of the brushes. He wrapped the EIDE cable around the drill and ran the drill during the test trying to introduce a great deal of interference - the design worked perfectly. At that point, I knew I was working with the right engineer for the project. Be sure to spec zero halogen cable for those 737 installations. ![](/ubbthreads/images/graemlins/wink.gif)
#292920 - 27/03/2007 05:42
Re: We Have Lights!
[Re: MarkM]
So MarkM, reading the posts suggests you may do some 'interesting' installs on some nice cars...
If that's the case, have you come across the 2005 model Jaguar XK? I have an install problem with it....
Running twin 30's
#292921 - 27/03/2007 18:53
Re: We Have Lights!
[Re: LittleBlueThing]
I have very little experience in hands-on installation - I leave that work to the pro install shops. It's often frustrating for people who do this every day.
That said - lets hear it. Online forums or a dealer service manual are your friend. Post your problem here, chances are someone has the answer.
#292922 - 27/03/2007 20:24
Re: We Have Lights!
[Re: MarkM]
Well I would really like to take out the standard DIN Jag head unit and replace it with the empeg - it'll look better than having to make something up for the extender.
The problem is that when you remove the head unit the satnav doesn't work. Rumour suggests that the satnav notices the head unit security state (ie missing or 'code' not entered).
So I need to bypass the satnav security - quite specific to Jaguar (and Google suggests maybe Volvo) I guess.
Running twin 30's
#292926 - 28/03/2007 01:06
Re: We Have Lights!
[Re: maczrool]
Quote: Patrick says he's tested it to 100 meters, and I think he said somewhere it might work up to 200 meters! Now who is going to put it to the test and see what the limit really is?
Stu
Well, that's pretty obvious: the only guy here who we all *know* has (or will have soon) over 100m of ribbon cable is..
..lemmesee.. say, another 15 of these yet to be assembled/sold/shipped = 15 * 7m each = 105m of ribbon cable, Stu! ![](/ubbthreads/images/graemlins/wink.gif)
Cheer
#292927 - 28/03/2007 01:25
Re: We Have Lights!
Loc: Louisiana, USA
Quote: Well, that's pretty obvious: the only guy here who we all *know* has (or will have soon) over 100m of ribbon cable is..
I can do a 100 feet right now, but beyond that it's just pieces that have already been cut to 20 foot lengths. I'm trying to find 200 meter+ spool, so far I can't seem to find one longer than 100 feet and we already know that works .
Edit: I did locate a reasonably priced 100 meter spool. I might use that for the next batch and just for fun attach a connector to either end and fire up the extenders before cutting it up. Still, it would be more fun to try it on a 200 meter or more cable.
Stu
Edited by maczrool (28/03/2007 01:42)
#292928 - 28/03/2007 03:23
Re: We Have Lights!
[Re: maczrool]
This is too funny. Now I'm thinking of a neat picture at Qwest field with a ribbon cable running from one endzone to the other. That would be one for the empeg archives.
#292929 - 28/03/2007 03:41
Re: We Have Lights!
[Re: MarkM]
Quote: This is too funny. Now I'm thinking of a neat picture at Qwest field with a ribbon cable running from one endzone to the other. That would be one for the empeg archives.
Now if you get the manager of Qwest field to sit with some headphones in one end zone with the remote display (while controlling the Empeg in the other end zone) that would be cool.
But no outputs on the display. 100 meter headphone cord.
Jim
