#298928 - 04/06/2007 02:19 Bad HDD? ide_data_test problem?
Allistah
Hey all..
I have a MkII unit and I upgraded the hard drive a couple of months ago. Things have worked fine since then. Then one day it said I had no playlists. I connected it to Emplode and that fixed that problem. Then I took it out to the car and it said no hard disk found. Now when I boot it up this is what it has on the serial port. I'm hoping that someone can tell me what is going on here. Thanks.. -Allistah
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v467 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Mon Jan 15 17:40:42 EST 2007
Processor: Intel StrongARM-1100 re
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101431) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0004380).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
ide_data_test: wrote 0x5555 read 0x8080
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
smc chip id/revision 0x0249
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Edited by Allistah (04/06/2007 02:22)
#298929 - 04/06/2007 12:18 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Looks like the hard disk cable has become unplugged from the drive or the mainboard.
#298930 - 04/06/2007 14:36 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
Well, thats what I thought first off too. I pulled the lid off and the cable was seated perfectly fine on the drive and the mainboard. I pulled the cable off and looked close at it and it kind of looked like the connector wasn't fully pressed onto the ribbon cable. So I took a pair of plyers and gently squeezed the connector all the way across so the cable was well seated on the connector. I plugged it all back in and I got the same thing. I guess when I get home tonight I could try the connector for the second drive and see if that changes anything. I looked at the connector on the mainboard and it looks like it's attached (soldered) just fine. I didn't see any traces being pulled up or anything.
Any other suggestions?
#298931 - 04/06/2007 15:03 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Oh, wait a minute.. the log shows other, more serious, issues.
Those devices share the same signals as the IDE bus, and one or both of them
seems have gone bad here.. Serious surgery time.
#298932 - 04/06/2007 15:07 Re: Bad HDD? ide_data_test problem? [Re: mlord]
The real puzzler, and best clue, is that the readback tests show 0x0000 practically every time. To me, this suggests a problem with the chip select, control, or address signals on that bus, rather than the usual dead CS4231A or SMC chip.
#298933 - 04/06/2007 15:21 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
Hm, any suggestions on what I should do to try and repair it? Or do you have any suggestions for something that I should read or anything like that? I'm decent with an iron so that doesn't scare me, except for some larger surface mount stuff because I don't have the hot air tools to get those off the board.
#298934 - 04/06/2007 15:38 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Well, if you have a logic probe, and perhaps a logic analyzer, then start with the signals that are easily accessible on the IDE header. Those are publicly documented in the ATA Standards (t13.org). So you can trace what's happening on the header pins, and see whether the R/W, CS0/1/2 ... etc.. signals are actually working or not. Also probe for stuck data lines.
This may be easier if you hack the kernel to hold known data patterns on the pins for longer periods than what normally happens during probiing.
And/or trace the signals backwards from the header towards the CPU. Most of them go through some LS TTL buffers, and it is possible that one of those buffer chips is not working. Tracing them back is pretty much the only option, as the schematics are not redistributable.
I believe that only RobS, Patrick, and Hugo have access to the full schematics.
I have previously reverse-engineered much of this circuitry to diagnose similar problems,
but that knowledge is not in any form I can pass directly along.
#298935 - 04/06/2007 23:41 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
I don't have access to a logic probe so all that is out.. :-( Anything else I can do or is this thing pretty much hosed?
#298936 - 05/06/2007 01:51 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
You can send it to Rob Schofield for diagnosis/repair, but he's really been out of things for the past 3 years or so.
Or failing every other option, you can send it to me for an exact diagnosis. I can also repair it, except for the really large surface mount chips (eg. the SMC or CS4xxxx chips are too large for my skills/equipment). But I'm really the ultimate final resort here, as I lose money on such repairs and it may take several weeks before I can fit it in.
#298937 - 05/06/2007 03:34 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
What is the best way for me to talk to you about these options offline? Can I email you directly or something? What would be best for you? I'd like to discuss the options you've described.
#298938 - 05/06/2007 11:48 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Email is best.
Unlike you, I've actually filled in my BBS profile, email address and all.
#298939 - 16/06/2007 13:35 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
shapeless
Loc: Italy
urhm, i've a problem like yours posted here
http://empegbbs.com/ubbthreads/showflat.php/Cat/0/Number/300526/an/0/page/0#Post300526
sounds strange, don't you think ?
shapeless
MK2a | #010101588 | 2x 120GB SSD  | Hijack v526 | v3.0a11 | > melpomene <
MK2   | #090000581 | 60 & 100GB HD | v2final.mk2 | v2.01 | > backup <
radio | all colors lens | greenlights LBSSK buttons | KCA-R6A + ERC-1A remotes | carry cases | empeg sticker!
#298940 - 04/07/2007 20:04 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
Mark, I've sent you email. Let me know if you don't get it.
Thanks,
-Allistah
#298941 - 04/07/2007 23:49 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Hi. No sign of it here. Try again?
(Since my email is *very* public, and has not changed since 1996 or so, I get a LOT of spam, and therefore have many layers of spam filters.. )
#298942 - 14/07/2007 13:17 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
Ok, I just sent it again. It will be from Jaime Pirnie ([email protected]) and the subject is: "Broken Empeg - You might be able to repair?"
Let me know if you still don't get it and I'll PM it to you.
#298943 - 14/07/2007 16:06 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Got it, replied to it.
#298944 - 14/07/2007 20:44 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
When looking close at the CS4231A chip oriented in the position so you can read the text on the chip itself, there are two pins on the right side that have a solder bridge between them a little over half way up from the bottom near you. Supposed to be like that? I didn't put it there.
I was going to start troubleshooting with taking this guy off and see if anything improves. If I remove the chip, should I post the output again? Actually, I'll remove the bridge first and see if that does anything and if not I'll remove the entire thing.
Edited by Allistah (14/07/2007 20:47)
#298945 - 14/07/2007 20:58 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
maczrool
Loc: Louisiana, USA
There is a bridge that should be there. Get the datasheet for the chip and it should confirm it.
Stu
#298946 - 14/07/2007 21:27 Re: Bad HDD? ide_data_test problem? [Re: Allistah]
Leave that bridge alone!! It is supposed to be there.
If you remove the chip, your player *must* have a recent Hijack kernel in order to work. Hijack provides the necessary workarounds for a missing/dead CS4231A chip.
#298947 - 15/07/2007 03:07 Re: Bad HDD? ide_data_test problem? [Re: mlord]
Allistah
Heh, too late, it got removed. ..and it currently has your disk formatter kernel installed. Before I do any more damage than just removing the solder bridge, I think I'll just send it to you.
