#299471 - 16/06/2007 10:11 Empty playlists on web interface
theGecko
Loc: Cambridge, UK
I've got a bit of an odd problem and can't seem to fix it.
Also checked the forums to no avail, so I apologise if this has been seen before.
My player is working absolutely fine, but the web interface shows an empty main playlist :/ (only Unattached items is visible)
I can see the fids by browsing to /drive0/fids and can even pick other playlists by changing the URL from /?fid=101... to something such as /?fid=121
Notify is on and everything else works (downloading, playing, etc.) it just seems that the main playlist has nothing attached on the web interface only. Any ideas?
1995 Audi Coupe Quattro 2.8 - empeg MKII 80GB [090000613] 1970 VW beach buggy being built - empty sled
#299472 - 17/06/2007 00:44 Re: Empty playlists on web interface [Re: theGecko]
That's one for the blue names to respond to. The Hijack web interface uses the actual FID files (and tag files) for it's interface, whereas the player software uses the binary pre-built database, so it is quite possible that one might work when the other fails. But *why* it has failed is the interesting question.. Peter, Roger ??
#299473 - 17/06/2007 11:12 Re: Empty playlists on web interface [Re: mlord]
theGecko
Loc: Cambridge, UK
Hmm I'm wondering if there is a problem with the first '101' playlist fid. Would someone mind posting a sample one for comparison as I can see they are basically text files?
#299474 - 17/06/2007 14:57 Re: Empty playlists on web interface [Re: theGecko]
The format is documented here.
#299475 - 17/06/2007 20:40 Re: Empty playlists on web interface [Re: Roger]
theGecko
Loc: Cambridge, UK
D'oh! didn't realise the fids has binary counterparts
figured I'd resync a few times to try to resolve this and its started freezing when checking disk integrity. The player also comes up with '0940.6 nomem err' now too. Odd since all I've done to it is add a few more tracks and upgraded to the latest hijack :/
Rolled back to v468 and its still bust:/
Edited by theGecko (17/06/2007 20:49)
#299476 - 17/06/2007 22:06 Re: Empty playlists on web interface [Re: theGecko]
theGecko
Loc: Cambridge, UK
Hmm, an advanced search with refs>1 in emplode brings back the main Playlists folder (along with a few other bits). I can't remember if this is normal and if not would explain a recursion which could be leading to a memory leak and causing me these problems. I can't see it repeated in the folder tree, though.
#299477 - 18/06/2007 07:34 Re: Empty playlists on web interface [Re: theGecko]
explain a recursion
emplode actively removes circular references (loops) in the playlist graph, so you shouldn't see this. I don't know if there's a maximum depth allowed in the playlist tree, but it's gotta be quite big.
#299478 - 18/06/2007 08:07 Re: Empty playlists on web interface [Re: Roger]
theGecko
Loc: Cambridge, UK
The tree can't be more than 10 levels deep (it's quite a flat structure).
Still not sure whether this is the problem (would anyone mind telling me if an advanced search with refs>1 brings back the main playlists playlist?), but if emplode fixes it, it never reaches the point where the database is uploaded cos it falls over when checking disk integrity.
#299479 - 18/06/2007 09:55 Re: Empty playlists on web interface [Re: theGecko]
No. "refs" is the number of references _to_ a playlist, not _from_.
#299480 - 18/06/2007 12:31 Re: Empty playlists on web interface [Re: Roger]
theGecko
Loc: Cambridge, UK
So multiple references to the main playlist is bad Can I force a rebuild without this? Removing the main fid perhaps?
Cheers fotr your continued help
#299481 - 19/06/2007 07:53 Re: Empty playlists on web interface [Re: theGecko]
theGecko
Loc: Cambridge, UK
Woohoo! Got it working
I found that the disk integrity check was running every time, so fixed that with FSCK. Synching was then happy, but the web playlists still didn't work. I figured it was still a problem with the root playlist, so deleted it using jEmplode (emplode won't let you do this). A sync on jEmplode made it all very messy, so I didn't save it. Instead a sync with emplode rebuilt the root playlist (and renamed it from playlists to allmusic :/).
Don't know what the problem was or how I caused it, but all is now good.
