#340463 - 20/12/2010 15:51 iTunes Synch to USB
I'm picking up my new Volvo on Thursday, the headunit will read up to 60000 files off a USB HDD but only 500 folders, I've tried MediaMonkey and WinAmp to synch the HDD to my MP3 library but both create huge numbers of folders. I've been told an iTunes library is the way to go, never having used iTunes I can't see how exactly to get my library currently J:\MP3\ to the HDD via iTunes.
How do I do this?
#340464 - 20/12/2010 16:44 Re: iTunes Synch to USB [Re: tahir]
Hmm, not sure about that. My iTunes folder (as organised by iTunes itself) has one folder per "album", enclosed within one folder per artist... ie, pretty much the same as I organised my flacs during ripping.
Does the volvo browse the folder tree? Sounds like you maybe need to manually work on how you'd like to browse your music.
Sounds strangely like an empeg playlist tree is required smile
#340470 - 20/12/2010 23:57 Re: iTunes Synch to USB [Re: altman]
I also find it strange that it can handle 60000 files but only 500 folders. 120 files/folder without any allowance for Artist\Album\Track etc?
I don't see how iTunes can make it any better. It still needs to store the files. Sounds like someone has just said "iTunes" since that magically fixes everything....
Sure about the 500 folder limit? Maybe just give it a go? Thursday's not that long to wait to find out.
Worst case do you think you'd have 500 artists?
In my store I keep it like this:
A\
   Artist 1
      Album 1
         Artist 1 - Album 1 - 01 - Trackname.mp3
      Album 2
         Artist 1 - Album 2 - 01 - Trackname.mp3
   Artist 2
      Album 1
         Artist 2 - Album 1 - 01 - Trackname.mp3
B\
   B Artist 1
through
Z
with special "Comedy", "Audiobooks" and "Various" at the top levels.
In my case I could probably just get away with removing the Album subdir and dropping one artist's tracks all in one directory. That's assuming of course the Volvo is smart enough to sort alphabetically and doesn't leave them in file system order.
#340475 - 21/12/2010 08:45 Re: iTunes Synch to USB [Re: Shonky]
I appear to have 4025 artists. I've got my iTunes library on the HDD now, will wait till I pick the car up to see if it works. The library has been organised as Artist\Album which means lots of Album folders on various artists compilations.
#340476 - 21/12/2010 08:52 Re: iTunes Synch to USB [Re: altman]
Yeah I was hoping NOT to change my directory structure, I've got5 directories under MP3:
AF
GM
NS
TZ
Under which I have Artist\Album
plus Various which contains all the multi artist compilations under which I have Label\Album
The Volvo can browse the folder tree and I guess this may be where the folder limitation lies, maybe stuff off playlists will be OK.
Never played with an empeg so unfortunately no idea what a playlist tree looks like.
#340477 - 21/12/2010 10:58 Re: iTunes Synch to USB [Re: tahir]
It seems to me that Doubletwist would be better at syncing to a USB mass storage device. But I might not be understanding the problem correctly...
#340478 - 21/12/2010 11:24 Re: iTunes Synch to USB [Re: Dignan]
Not sure what Doubletwist would do for me, I now have the library on the HDD, problem is going to be the number of folders
#340479 - 21/12/2010 12:21 Re: iTunes Synch to USB [Re: Shonky]
Yet another product where the progammer used fixed length arrays. Sweet.
#340485 - 21/12/2010 15:23 Re: iTunes Synch to USB [Re: tman]
Maybe you'll be lucky, and the description of the limits were an oversimplification? Maybe the 500 limit is only per-tree-level, i.e., you could have 500 root folders, and 500 folders at the next tree level, etc...
#340493 - 21/12/2010 16:53 Re: iTunes Synch to USB [Re: tfabris]
We shall see...
#340499 - 21/12/2010 21:37 Re: iTunes Synch to USB [Re: tahir]
Wait, what?
That's a lot but it all depends on how you organise your music. For full albums I keep an artist directory and subdirs for each album under that. For singles they go in one big folder currently. So for my current 75GB odd collection I only have (yes exactly!) 500 folders including the top level A through Z and a few other top levels but excluding the actual album folders.
#340504 - 22/12/2010 08:06 Re: iTunes Synch to USB [Re: Shonky]
Wait, what?
Yeah, I know...
#340505 - 22/12/2010 08:07 Re: iTunes Synch to USB [Re: Shonky]
Let's swap libraries
