#363191 - 01/01/2015 12:34 Hijack reports "405 Method not allowed" when GET has content-length: 0
I'm using https://github.com/inaka/shotgun to talk to the Hijack HTTP server. When I do the following:
{ok, C} = shotgun:open("10.0.0.21", 80).
shotgun:get(C, "/").
...Hijack returns "405 Method Not Allowed". The request looks like this, according to wireshark:
GET / HTTP/1.1
content-length: 0
host: 10.0.0.21
Moreover, the Hijack response is contradictory, in that it looks like this:
HTTP/1.1 405 Method Not Allowed
Connection: close
Allow: GET, HEAD
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head><title>405 Method Not Allowed</title></head><body><h1>405 Method Not Allowed</h1>Server only supports GET<p></body></html>
The "Allow: GET, HEAD" contradicts the "Server only supports GET" message.
#363197 - 01/01/2015 20:07 Re: Hijack reports "405 Method not allowed" when GET has content-length: 0 [Re: Roger]
Weird. I wonder if it processes the GET okay, and then tries to interpret "content-length" as the next command in the pipe?
What does "content-length: 0" mean here, anyway? "Send me up to 0 bytes?"
Once I understand the request, I can fix Hijack.
Thanks.
#363198 - 01/01/2015 20:12 Re: Hijack reports "405 Method not allowed" when GET has content-length: 0 [Re: Roger]
Mmm.. reading about it now: "content-length" is meaningless when part of a GET request, and shouldn't really be sent by the client. Nothing seems to forbid it though, so I'll add support for "content-length: 0" on GET.
#363199 - 01/01/2015 20:16 Re: Hijack reports "405 Method not allowed" when GET has content-length: 0 [Re: Roger]
Does this work for you? (Hijack zImage attached)
zImage.bin (254 downloads)
Description: Hijack zImage file which allows/ignores "Content-length: 0" in GET,HEAD requests.
#363202 - 02/01/2015 08:23 Re: Hijack reports "405 Method not allowed" when GET has content-length: 0 [Re: mlord]
Per https://tools.ietf.org/html/rfc7230#section-3.3.2:
A user agent SHOULD NOT send a Content-Length header field when the request message does not contain a payload body and the method semantics do not anticipate such a body.
I'll also raise a bug against the client library I'm using.
