#366347 - 24/03/2016 23:04 How to remove silicone?
CrackersMcCheese
5 years ago I had the smashing idea of using silicone to stick my toilet roll holder etc to the tiles, rather than drilling my lovely new bathroom tiles.
However, now it's time to change these items and I cannot get rid of all of the silicone. I have removed most of it with a Stanley blade but I am left with a silicone corona that I notice everytime I walk in the room. It also gets dirtier quicker.
I've only tried scrubbing with a metal pot scourer but that had no effect and I am hesitant to try anything harder incase I scratch the tiles. Would sandpaper work? I suspect that if a solvent existed it would be extremely dangerous and not available to me anyway.
Any advice?
Edited by Phil. (24/03/2016 23:05)
#366348 - 24/03/2016 23:28 Re: How to remove silicone? [Re: CrackersMcCheese]
I don't have any advice, but I wanted to mention that "Silicone Corona" is the name of my Brian Eno cover band.
#366349 - 25/03/2016 00:06 Re: How to remove silicone? [Re: CrackersMcCheese]
Originally Posted By: Phil.
... I suspect that if a solvent existed it would be extremely dangerous and not available to me anyway.
There is a silicone remover product available in retail. It is specific to silicone and is not as effective on other types of adhesives or caulking compounds.
We have used the DAP product.
DAP Silicone Sealant Remover
Apparently WD-40 can be applied to good effect. I use WD-40 for general goop removal but not (yet) for silicone.
Google search turned up these products which I had not seen before.
DSR-5
McKanicaź Silicone Caulk Remover Gel (0354)
I use a Razor scraper to shave the surface as much as possible. I find the single edged razor blade scraper to allow a very close 'shave' of the surface, which often removes all but the thinnest residual film of unwanted material.
Edited by K447 (25/03/2016 01:56)
#366350 - 25/03/2016 06:25 Re: How to remove silicone? [Re: CrackersMcCheese]
In Australia this stuff worked reasonably well but I still had a bit of the ghost of the silicon still there. It didn't matter much in my case though. The best thing I found was simply a razor blade/scraper run along the surface of the tile.
http://www.selleys.com.au/sealants/silicone/remover/
Edited by Shonky (25/03/2016 06:26)
Edit Reason: Added bit about razor bade
#366351 - 25/03/2016 12:32 Re: How to remove silicone? [Re: CrackersMcCheese]
I just rub the silicone with my thumb/fingers, and it eventually all rolls off. Rough textured leather gloves also work for me.
