#43968 - 28/10/2001 03:37 Empeg & Rio Reciever
JaBZ
Loc: NZ
Couldn't find this Question by searching, also
Not sure where I should have posted this, but this board is used way more than the receiver so here goes...
Is it possible to have the MK2 player serve music for a Rio Receiver? (Via Ethernet)
If not is it hackable to do so?, This should be pretty easy wouldn't it?.....Would RAM be a limiting factor?, Does the Rio Receiver have it's own RAM?
Jaidev
#43969 - 28/10/2001 07:15 Re: Empeg & Rio Reciever [Re: JaBZ]
I think it read empeg did it as a demo but they aren't releasing anything to allow it to be done
I thought I wanted to do that but the screen on the reciever doesn't look much bigger than the empeg one
#43970 - 28/10/2001 10:35 Re: Empeg & Rio Reciever [Re: JaBZ]
time
Loc: Southwest
It is a memory limitation as cited here.
Unfortunate eh? It would sure be slick....
#43971 - 28/10/2001 11:06 Re: Empeg & Rio Reciever [Re: msaeger]
schofiel
It's smaller, believe me.
#43972 - 28/10/2001 15:45 Re: Empeg & Rio Reciever [Re: JaBZ]
fvgestel
Loc: Netherlands
Setting it up on the empeg would mean you should setup on the empeg:
- a bootp/dhcp-server for assigning an IP-address to the the receiver
- NFS software to export the root filesystem (kernel, executables, configuration)
- an SSDP-server for directing requests to the empeg
- an HTTP-server for serving metadata as well as mp3's
I have been thinking of incorperating the receiver type HTTP-requests in displayserver, but haven't had the time for it. the other components should be implemented also, so it would only cover half the needs...
If you want to set something up yourself, look at http://www.mock.com/receiver/
Frank van Gestel
#43973 - 29/10/2001 04:22 Re: Empeg & Rio Reciever [Re: fvgestel]
The installation notes for jreceiver are very good at explaining the NFS machinations, too. You just need to apply the logic to your empeg.
#43974 - 06/09/2002 22:05 Re: Empeg & Rio Reciever [Re: fvgestel]
Daria
Has anyone done it? I actually intend to to do some other stuff later but it seems like it won't suck to do this now. Maybe I'll have time tomorrow.
#43975 - 06/09/2002 22:09 Re: Empeg & Rio Reciever [Re: schofiel]
grgcombs
Loc: Dallas, TX
In cm I'm guessing it's smaller, but in pixels it's bigger ... 128x32 for the empeg, 128x64 for the rioreceiver.
Greg
