#45443 - 07/11/2001 16:00 Tuner Volume and Remote
DanMcC
I have a Mk2 unit (#686) upgraded to 1.03, and just installed the tuner module. I seem to have a couple of problems.
1. FM volume is WAY down. I tried getting rid of the extension harness, and have verified that the antenna connection is good. AM volume is good, but for FM I have to turn the volume up over 0 dB to hear it, and the quality is not good.
2. I have the Kenwood remote. When I press the ‘DNPP’ button while following the instructions for setting the presets, I get a horizontal line across the top of the screen, and nothing else seems to happen.
Help?
Dan
#45444 - 07/11/2001 16:18 Re: Tuner Volume and Remote [Re: DanMcC]
Your car's antenna amplifier is not connected properly and is not getting powered up. See the troubleshooting section of the FAQ at riocar.org.
Known bug, fixed in the next (2.0b3) release.
Note that 2.0b3 is still in beta and it has its own set of bugs, use it at your own risk.
#45445 - 07/11/2001 17:22 Re: Tuner Volume and Remote [Re: tfabris]
DanMcC
Thanks Tony. Unfortunately my car did not come with an antenna amplifier. Off to the stereo shop on the weekend.
Dan
#45446 - 07/11/2001 17:33 Re: Tuner Volume and Remote [Re: DanMcC]
You sure? What kind of car is it?
#45447 - 07/11/2001 22:33 Re: Tuner Volume and Remote [Re: tfabris]
What kind of cars do include antenna amplifiers? I've never seen one over here (Canada), and I've poked at a fair number of car stereos (10 or so).
#45448 - 07/11/2001 23:38 Re: Tuner Volume and Remote [Re: mlord]
Many european models, as I understand it. My '80's-era VW had a bee-sting antenna with the amplifier in its base.
#45449 - 08/11/2001 00:10 Re: Tuner Volume and Remote [Re: tfabris]
Diznario
Loc: Portland OR
I think VW has been on the powered antenna tip for a while. I seem to recall other VWs haveing powered antennas as well. They might be one of the few manufacturers that use them though, because you hardly ever see them. No car I've ever owned, or helped install a sterio in has ever had one.
If I'm not misstaken, the New Beatle comes stock with one of the new Fuba antennas. Probably very similar to what you had.
It's a pretty slick antenna, and I was thinkin about stickin one on my car.
Dario
MK2 in an Impreza 2.5RS
#45450 - 08/11/2001 05:28 Re: Tuner Volume and Remote [Re: Diznario]
Most (all?) VWs have them, ditto for audis. Many Mercedes and BMWs have in-glass antennas, which are amplified too.
#45451 - 09/11/2001 04:07 Re: Tuner Volume and Remote [Re: mlord]
johnmcd3
My BMW has one (as do other BMWs without a visible antenna) and believe it or not its in the backseat support column behind the drivers door. It requires 12v to operate (which is wired to the factory radio, so its only on when the radio is on) and when I replaced my radio / with the empeg, I needed to hook up the tuner modules antenna remote line to this. My previous car (Camaro, like many other US cars) did not have this.
1998 BMW ///M3 30 GB Mk2a, Tuner, and 10 GB backup
