#52861 - 31/12/2001 10:42
Disconnect button in emplode
Loc: Germany (Ruhrgebiet)
Hi.
I would really like to see a disconnect button (or at least menu function) in emplode again. I need to setup the network parameters quite often when moving the player around, just before actually uploading music. It is a bit inconvenient (and time consuming) to have to close and re-open emplode instead of just disconnecting/reconnecting (switching from serial to ethernet) like I used to do it with emplode 1.*.
cu,
sven
#52862 - 31/12/2001 10:54
Re: Disconnect button in emplode
[Re: smu]
Er, you can just close the MDI child window.
#52863 - 31/12/2001 10:54
[Re: smu]
Won't simply closing the current "child window" in emplode accomplish what you want?
To the left of the "File" menu is an icon. Click on that and press "Close". Is that what you wanted? The shortcut to this is supposed to be Ctrl+F4, but I just noticed the shortcut doesn't work in 2.0b7, so I'll report that one. (Alt+dash followed by C works though.)
#52864 - 31/12/2001 11:00
Okay, the following bug report has been filed:
"If you directly click on an item in the left-hand pane (for example, "playlists" or "all tracks" or "artists"), setting the actual focus to an item in the left-hand pane, then the Ctrl+F4 shortcut for closing the window does not work.
If you focus the right-hand pane by clicking anywhere in it, then Ctrl+F4 works again."
#52865 - 31/12/2001 11:16
Yeah, and there's nothing specific in the code to handle Ctrl+F4 in either case, so I don't know why it's getting swallowed when the LHS has the focus. Hmmm...
#52866 - 31/12/2001 13:06
[Re: Roger]
Ah the joys of using Microsoft's user-interface libraries.
#52867 - 31/12/2001 15:17
Hi.
I didn't realize it was a MDI application until I read it in this thread (I remember now, though, that I read it before). Ok, let me rephrase my wish then:
I want a File->close menu entry (that's what I looked for in the first place).
Wouldn't that top menu entry better be named "Player" or "Database" instead of File? Reading File there might be Windows-Standard, but I keep associating that menu entry with the individual files on the player rather than the player itself.
Additionally: What sense does a MDI make, when there is no way to open a second "document" (player database) anyway?
Edit: As you might see in my other post, I now realized what sense it might make (opening a second window of the same player database).
cu,
sven
Edited by smu (31/12/2001 15:23)
#52868 - 31/12/2001 15:22
[Re: Roger]
Hi.
Might be that the LHS is not really part of the MDI window, but a main window part that happens to only be visible when the player database is open.
Hmm, no, I just checked, it is at least displayed as a part of the MDI window.
cu,
sven
#52869 - 31/12/2001 20:06
They're not called MF classes for no reason.
#52870 - 31/12/2001 20:23
[Re: smu]
There's nothing specifically in emplode that stops you opening more than one player at a time, except that the menu option is not available....
#52871 - 01/01/2002 02:03
[Re: Roger]
Considering the fisrt time I had access to two players at once was today, this feature would be nice. (Hopefully) there will be a third player running around the network soon.
What would be even nicer would be drag and drop support between the two windows, allowing easy cloning in pieces to a new player, or syncing files between the player and HSX...
#52872 - 01/01/2002 02:25
ROFL!
Perfect!
#52873 - 01/01/2002 04:07
[Re: drakino]
That's why you can only open one at a time -- there's no support for this.
#52874 - 01/01/2002 04:37
[Re: smu]
I find it very useful for various playlist reshuffles and cleaning ups.
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#52875 - 01/01/2002 05:49
[Re: Roger]
Loc: England
Am I missing something here? I've opened two windows in Emplode before to make it easier for moving stuff around. I've just tried it in 2.0b7 and it still works. I'm confused  .
Marcus
#52876 - 01/01/2002 06:40
[Re: beaker]
Yeah but they were on the same player - not two different players.
#52877 - 01/01/2002 06:52
[Re: rob]
Loc: England
Ah Right, I see what you're talking about now. Doh!!
Marcus
#52878 - 01/01/2002 07:36
[Re: Roger]
Hi.
Ah, right, STRG-O does work. Now if "Copy" would work between different players, that would be extremely useful for people with multiple players and/or people meeting other empeg owners.
cu,
sven
Edit: Yeah, I posted this before reading the rest of the thread.
Edited by smu (01/01/2002 07:44)
#52879 - 01/01/2002 11:15
[Re: smu]
Well, it shouldn't. FITNR.
If, at some point, we do add functionality to enable copying between players (and that'd be up to the lawyers), I'll re-enable it.
#52880 - 01/01/2002 11:50
[Re: Roger]
Of course, I immediately scrambled to my 2.0b7 Emplode, opened up the car player, pressed CTRL-O, and opened up the HSX-109.
I actually could drag a song from the car player to the HSX, but it never actually copied the song. After the synch, it wasn't there on the HSX.
Oh well, hopes dashed.
