#77202 - 02/03/2002 18:07 clearing plays
darwin
can someone tell me the easiest way to clear the plays? (the number of times a song is played)
#77203 - 02/03/2002 20:30 Re: clearing plays [Re: darwin]
I think I read roger said you can't
#77204 - 04/03/2002 00:34 Re: clearing plays [Re: darwin]
darwin
I was thinking if i downgrade to 1.03 and then back up to 2.0b11 it might work, because I don't think the plays started until 2.0bx. Can't hurt, right?
#77205 - 04/03/2002 07:39 Re: clearing plays [Re: msaeger]
Can't be done? What does "Reset Metadata" in the right-click menu of Emplode do, then? I've never used it but I assumed that it cleared things like the play count, marked status, etc.
#77206 - 04/03/2002 08:36 Re: clearing plays [Re: tonyc]
No, it resets the 'codec', 'duration' and 'offset' tags. Resetting the dynamic data (play/skip count) is not supported by the emplode/emptool protocol -- effectively, it's read-only as far as emplode is concerned.
If you want to nuke the lot, then write zeroes all over the dynamic data partition.
#77207 - 04/03/2002 10:01 Re: clearing plays [Re: Roger]
Think resetting the dynamic data stuff would be an achievable post-2.0 wishlist item?
