#78481 - 07/03/2002 20:18 Freezing at the boot up logo screen
newguy1
Loc: Massachusetts,USA
I received my replacement cable and just installed it.I then loaded about 5 songs on it.During the synch it failed while starting player but it rebooted ok .Then i added a few more songs and now its stuck on the boot up logo screen.I read the FAQ and it says could be a bad hd or loose cable.In hyperterminal all i get is a repeating 47101>too large message now what?
MIKE 80Gb RIO
#78482 - 07/03/2002 21:07 Re: Freezing at the boot up logo screen [Re: newguy1]
Please post the exact text you see on the serial port ("hyperterminal").
#78483 - 07/03/2002 21:13 Re: Freezing at the boot up logo screen [Re: mlord]
newguy1
Starting bash.
no shell!
Shell exit
kmalloc: Size (147101) too large
hijack: no memory for parsing config.ini; skipped
[hijack] ERROR: : "no memory"
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Loading dancefile: "/empeg/lib/visuals/breakdance.raw"
Loading dancefile: "/empeg/lib/visuals/stonkdance.raw"
Loading dancefile: "/empeg/lib/visuals/princedance.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
Does this help?
Edit: this is what is showing now. I was able to install v233 of hijack,but when it boots the message says hijack config error
Edited by newguy1 (07/03/2002 21:17)
MIKE 80Gb RIO
#78484 - 07/03/2002 21:21 Re: Freezing at the boot up logo screen [Re: newguy1]
Good. Now fix your config.ini file.. it has about a zillion "favorite visuals" entries in it, courtesy of a well-known bug in the Emplode software (soon to be renamed Explode).
#78485 - 07/03/2002 21:23 Re: Freezing at the boot up logo screen [Re: mlord]
newguy1
Ok thanks,uhh how do i do that?
MIKE 80Gb RIO
#78486 - 07/03/2002 21:29 Re: Freezing at the boot up logo screen [Re: newguy1]
If you are UNIX-proficient, then use a Unix/Linux box to FTP to the player, and grab /empeg/var/config.ini, and edit the file. Then re-upload it using FTP, in conjunction with "SITE RW" and "SITE RO".
Do NOT do that from any Microsoft operating environment, since most editors there will corrupt the file (adding the ^M characters).
If you are stuck with billg, then check the Empeg FAQ for how to enable "editing of config.ini" from within Emplode and then go that route instead.
When editing the file, find the "[VisualFavourites_XXX]" sections, and just nuke everything in them, including the header shown.
#78487 - 07/03/2002 21:30 Re: Freezing at the boot up logo screen [Re: mlord]
Or even better, locate & download JEmplode, and use it instead of Emplode for fixing the file. Much safer. There's probably a link to it somewhere on RioCar.Org
#78488 - 07/03/2002 21:39 Re: Freezing at the boot up logo screen [Re: mlord]
muzza
Or If you can sync in emplode (sorry, I can't tell from your posts), select Favourite Visuals under Tools. There should be many many many many many many visuals listed. For now, Remove all of them. This will not delete them off the player just you won't have a favorite visual set.
The detals of this are in the FAQ.
#78489 - 07/03/2002 22:06 Re: Freezing at the boot up logo screen [Re: muzza]
newguy1
Thanks guys, i think i got it now but its late so ill have to double check it on friday.And if i have any more problems ill be sure to post. thanks again
MIKE 80Gb RIO
#78490 - 08/03/2002 07:29 Re: Freezing at the boot up logo screen [Re: newguy1]
You're welcome!
