#81628 - 17/03/2002 11:27 jEmplode 29 - Save As Animated GIF
mschrag
Loc: Richmond, VA
http://www.jempeg.org/jemplode20.jar
I haven't done the Load From Animated GIF (I have to port the guy's code from JDK 1.2 back to JDK 1.1 so everyone can use it). But I added Save As Animated GIF... This is so you can send Drakino a thumbnail animation for RioCar.org.
Mike
#81629 - 17/03/2002 11:28 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
mschrag
Loc: Richmond, VA
Here's my hijack animation as an animated gif.
#81630 - 17/03/2002 11:29 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Have you licensed the GIF patent for this, or are we just flirting with litigation here?
#81631 - 17/03/2002 11:35 Re: jEmplode 29 - Save As Animated GIF [Re: mlord]
loren
shhhhhhhhhhh.....
|| loren ||
#81632 - 17/03/2002 11:37 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Here's the link for Unisys LZW / GIF patent licensing. I don't have one for IBM, who also have relevant patents. These patents (both companies) extend until sometime in 2003, so any unlicensed software which writes them is breaking the law (in the USA, and in treaty countries).
http://www.unisys.com/unisys/lzw/
Free the internet: use PNG instead.
#81633 - 17/03/2002 11:54 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
loren
II think it's time Jemplode got it's own link at the top of the BBS... maybe replacing the "empeg logos" link.. which is sorta redundant with the riocar.org link... sorta...
|| loren ||
#81634 - 17/03/2002 11:55 Re: jEmplode 29 - Save As Animated GIF [Re: mlord]
mschrag
Loc: Richmond, VA
Currently flirting with disaster ... I just did a search for AnimatedGifEncoder ... I'll track down an AnimatedPngEncoder and I'll switch it out. In the meantime, I suppose Unisys can send me to federal pound-you-the-a$$ prison
#81635 - 17/03/2002 12:03 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Heh, well I'll look into what I need to do on the logo site side. I figure with this, I'll do a 2 file upload screen, the preview, then the actual .raw file.
#81636 - 17/03/2002 12:09 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
jwickis
Loc: India
They have conjugal visits!!! Take care of your cornhole!
#81637 - 17/03/2002 16:22 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Hmm, just realised the animation only plays once. Can you make it loop?
And any luck on a PNG version? I should probably future-proof the logo site for this now since I have the code onscreen.
#81638 - 17/03/2002 16:35 Re: jEmplode 29 - Save As Animated GIF [Re: drakino]
mschrag
Loc: Richmond, VA
Yeah -- I can make it loop... No luck on the PNG one. Apparently PNG doesn't have animation built in, you have to use some format called MNG, which apparently IE doesn't support, which kind of sucks. I could do a large image that just draws all the frames concatenated? Mike
#81639 - 17/03/2002 16:49 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
What about Shockwave Flash? There is some code in PHP that can create flash movies, thus getting around the .gif issue on my side, and using a format almost every graphical browser can support (compaired to MNG support...)
Are there easy to use Flash libraries for Java? If not, a PNG image sequence might work, I'll just need to figure out a way to convert it to a flash movie either directly in PHP, or via a command line linux utility.
#81640 - 17/03/2002 19:20 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Why not just a simple Java applet that knows how to "play" the raw animations? I seem to recall that you're pretty handy with Java these days!
#81641 - 17/03/2002 20:28 Re: jEmplode 29 - Save As Animated GIF [Re: mlord]
mschrag
Loc: Richmond, VA
Uh. Hmm. I feel kind of stupid. It's amazing when you completely overlook the obvious solution I'll do that.
Mike
#81642 - 17/03/2002 22:21 Re: jEmplode 29 - Save As Animated GIF [Re: mschrag]
Heh, that would be easy
Just send me the web ready applet at my e-mail address. I'll get it up and have the site ready to go.
It will work best if the applet simply accepts a single URL to grab the raw file and play it.
#81643 - 18/03/2002 13:18 Re: jEmplode 29 - Save As Animated GIF [Re: drakino]
mschrag
Loc: Richmond, VA
http://www.jempeg.org/jemplode/AnimationApplet.jar
Check http://www.jempeg.org for the example use too (in the prereleases section).
Click on the animation to play it, play again to stop it... This is so if you have a lot of animations on one page, you don't take the hit right up front of tons of threads kicking off.
Mike
#81644 - 20/03/2002 17:57 Re: jEmplode 29 - Save As Animated GIF [Re: mlord]
eternalsun
Loc: San Jose, CA
At one point, I was in negotiations with Unisys on licensing for GIF. They wanted so much money I nearly laughed out loud on the phone. It's no wonder the format is going where it's going.
Calvin
#81645 - 20/03/2002 18:18 Re: jEmplode 29 - Save As Animated GIF [Re: eternalsun]
mschrag
Loc: Richmond, VA
You mean into the public domain in about 1 year?
