#81959 - 18/03/2002 17:12 Telnet Inclusion?
suomi35
Loc: Los Angeles, CA
How hard would it be to include telnet in hijack? Since we've already got inetd going with http and ftp why not add telnet in there as well? This topic seems to have faded a bit lately so I thought I'd blow the dust off it.
-Jason
#81960 - 18/03/2002 20:11 Re: Telnet Inclusion? [Re: suomi35]
Well, inetd is something completely different (not in Hijack), but also not really needed here for anything. (inetd is a super-daemon which binds to a lot of ports, and then spawns other daemons to handle incoming connections on those ports).
But telnetd is possible, though I don't see a compelling reason for it to be part of the Hijack kernel -- a userland telnetd app would be about the same size, and easier to play with once installed I suspect.
I once (like, a month ago) found some source code for a 100-line (C) telnetd from the 1980s -- no libraries or other package dependencies to speak of. Nice, compact, simple code. I even fiddled with maybe dropping it into Hijack at the time, but the syscalls work differently within the kernel and it was not to be.. but in userland, it should just drop in place and work. Lost the source though, and cannot for the life o'me remember where I found it.
But just go hunting with Google, for telnetd from say.. BSD 2.0 or something, and it'll be there. More recent versions are bloated with localization and extra security (eg. kerberos) and crap.. the older ones are nice lightweight simple code.
#81961 - 18/03/2002 22:55 Re: Telnet Inclusion? [Re: mlord]
suomi35
Cool! For some reason I thought that telnetd should need to be called along with httpd and ftpd...a userland telnet app would be fantastic, however. Thanks for clearing that up and keep up the good work!
-Jason
#81962 - 19/03/2002 05:09 Re: Telnet Inclusion? [Re: suomi35]
smu
Loc: Germany (Ruhrgebiet)
Hi.
I just found a telnetd source from 1989 at http://web.mit.edu/afs/athena.mit.edu/astaff/reference/4.3network/telnetd/
I will have a look at it as soon as I can (but probably not within the next fortnight, so if anyown has the time and knowledge to patch/compile it for the empeg, please do so.
Edit: We would also have to port /bin/login, which is also available in that web archive (just replace /telnetd with /login) in the above URL
cu,
sven
Edited by smu (19/03/2002 05:15)
#81963 - 19/03/2002 06:45 Re: Telnet Inclusion? [Re: smu]
Mmm.. a starting point for sure, but much larger than the one I had before, which "lacked" all of the "terminal" settings and stuff.
#81964 - 19/03/2002 16:50 Re: Telnet Inclusion? [Re: mlord]
foxtrot_xray
Loc: Atlanta, Georgia
That's actually the one I found (after your e-mail to me, Mark. BTW, I found your name while looking at 'hdparm' on my linux box. You're everywhere, man.)
I know next to nuthin' when it comes to C - I know enough to be able to get a basic understanding of what's going on, and I'm currently looking at the code and figuring out how to compile it for the ARM..
Hey, I'm learnin'.
#81965 - 19/03/2002 17:49 Re: Telnet Inclusion? [Re: foxtrot_xray]
NiCKEL
Loc: Vancouver, BC, Canada
Did anyone look at this thread:
http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_tech&Number=77116&page=&view=&sb=&o=&vc=1
Apparently they have a telnet server working. Source was posted.
I havn't had a chance to try it myself yet.
-Geoff
#81966 - 20/03/2002 01:30 Re: Telnet Inclusion? [Re: mlord]
jane
Loc: Copenhagen SW, Denmark
Writing a simplistic telnet server is really easy. I did this in Minix ages ago.... on an Atari computer.
1) Open and listen to a socket
2) when connected, use a PTY and exec a shell with
the appropritate stdin/out connected / piped to the network socket.
Marius (Escort Cab + Mark II)
#81967 - 20/03/2002 10:30 Re: Telnet Inclusion? [Re: NiCKEL]
foxtrot_xray
..Yes. And personally, I don't know a THING about Debian. They say there's alot of unresolved links, where you have to go find the librarys and such. It'd be much easier (IMHO, again I could be wrong, I barly know much when it comes to C) to just compile this small telnetd program, have it run as a daemon, and put the little 'login' program in /sbin. All good!
