The Home Media option allows you to share programming between boxes in your house, right? Well, I'm not sure this is possible with Turbonet Tivos (anyone?). What is possible is to capture shows to your hard drive for viewing, or burn them to DVDs.
If you go that route, the place for info is the Dealdatabase forums. There's lots of info. Basically follow the instructions you find, then I use the program called TyTool to do the actual extracting and such. I've been getting good results.
