#252368 - 23/03/2005 19:43
Re: e2fsck message at bootup, what does it mean?
[Re: bodybag]
Quote: My player still didn't build the database & playlists correctly? The playlist structure is in total chaos! I don't get it... why can't this player rebuild it's own playlist's right? Help please
You mean, the database rebuild completed and the player started, but the contents of the playlists aren't what you expected?
Once you've had messages like this from fsck:
Quote: Free blocks count wrong for group #3977 (0, counted=1). Fix? yes
then all bets are off. Your filesystem was corrupted and has been repaired as well as possible. Some files are probably corrupt. Sounds like some of them are playlist files. If you look at the player in Emplode/Jemplode/whatever then the playlists will be broken in the same way that they are on the player. Rebuilding the player's database only serves to reread the corrupted files: nothing on the player can recreate the pre-corruption versions.
As for what caused the filesystem corruption in the first place, the usual culprits are (a) crash or reboot with the filesystem mounted read/write, or (b) impending disk failure. But impending disk failure usually has other symptoms too.
bodybag
23/03/2005 02:41
bodybag
23/03/2005 03:04
bodybag
23/03/2005 04:24
bodybag
23/03/2005 04:29
bodybag
23/03/2005 19:27
bodybag
23/03/2005 19:50
bodybag
23/03/2005 20:18
bodybag
23/03/2005 20:45
bodybag
23/03/2005 21:04
mcomb
26/03/2005 04:23
