I have read through a lot of posts and the car FAQ to see what might be hanging me up. I am so close and just need a little push the rest of the way.
Here is my setup:
Server
> Windows XP
> Firewall turned off
> Plugged into Belkin F5D7234-4 wireless router with DHCP enabled and router firewall turned off
> Rio software has dchp turned off since I have the router doing that
Client
> Wireless Linksys WRT54GS2 running DD-WRT OS as client bridge
> Dell Rio Receiver pluged into Linksys WRT54GS2 ethernet port 1
Here is where I am at:
> Rio receiver initializes, shows searching for music and then reboots itself over and over again even if I turn it of and on multiple times. My music server shows the rio receiver in the counsel. I can ping the rio receiver from the server and it comes back successful.
So at this point I would not believe that there is a hardware issue since the server and rio client are taking to each other and the client is getting an ip address assigned to it from the router. I have not tried changing any port settings. Is this the next place to go? Does the "searching for music" use a different port than initializing the rio client? Or am I way off
Thanks in Advance!
Dennis
