Anyway, I've done as you suggested. My PC is set to 192.168.0.1 and I'm trying to set the empeg to 192.168.0 with the Subnet mask at 255.255.255.0 and blank for the Gateway.
Correct, but you didn't say what the last octet was in your player IP address. In your case, I would set it to 2 since your PC is 1.
is the true test pinging that address (once I've got my hands on the right cable)?
Once you've got your hands on the right cable, everything should work. Ping, emplode, whatever. Though you ought to consider just buying a cheap ethernet hub instead, so you can start really networking stuff.
___________
