#107621 - 27/07/2002 08:51 Identifying SMD resistors
I've got an SMD resistor that appears to have the code "100" on it. (Although I suppose it could be 001.) I want to know what value it's supposed to be. What resistance value should it show when tested?
#107622 - 27/07/2002 09:10 Re: Identifying SMD resistors [Re: tfabris]
It's done by YYX. Where YY is the first two digits of the resistance in ohms and X is the number of 0's after the two digits (multiplier)
So 100 should 10 ohms
- Trevor
#107623 - 27/07/2002 09:14 Re: Identifying SMD resistors [Re: tman]
Okay, cool, I'm reading 9.6 ohms, so this resistor is good. Thanks.
#107624 - 27/07/2002 12:57 Re: Identifying SMD resistors [Re: tfabris]
100 is likely to be 10 ohms; 10 and 0 zeros following it. eg, on the 3-digit SMD code, 103 is 10k (10,000 ohms).
Some are 4 digit, eg 1002 is 10k; on these 100 ohms would be 100R as it's a bit hard to have it make sense otherwise!
