#116921 - 18/09/2002 06:16 Using IR translation
newguy1
Loc: Massachusetts,USA
Ive used this great feature to do a couple changes to the remote but the one change i cant seem to get to work is to reverse the operation of the play /hush button.What i'd like to do is short press the buttun to hush; and long press to play/pause.I got the short press part to work but when I long press it still hushes instead of pausing/playing any thoughts?
MIKE 80Gb RIO
#116922 - 18/09/2002 19:57 Re: Using IR translation [Re: newguy1]
You might have to use the null operator to get it to work (search the Hijack FAQ for ``null''), but that's just a guess.
#116923 - 19/09/2002 10:03 Re: Using IR translation [Re: newguy1]
The sequence of translations in config.ini matters for stuff like this.
Try reversing the order.
#116924 - 20/09/2002 09:07 Re: Using IR translation [Re: mlord]
newguy1
Ok Thanks i'll try that
MIKE 80Gb RIO
#116925 - 25/09/2002 20:54 Re: Using IR translation [Re: newguy1]
Good luck.
