Have you determined from looking at the serial output whether or not there are two drives being recognized at bootup? What does the relevant section of the bootup text look like ("probing primary interface")?
This is what I got from booting thru hyperterminal but I have no idea what it means:
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 9, serial number 30103010)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Page cache hash table entries: 4096 (order
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9c37c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004480).
empeg RDS driver initialised
empeg power-pic driver initialised (first bo
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK4018GAP, ATA DISK drive
hdb: TOSHIBA MK4018GAP, ATA DISK drive
hda: TOSHIBA MK4018GAP, 38154MB w/0kB Cache, CHS=4864/255/63
hdb: TOSHIBA MK4018GAP, 38154MB w/0kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:61
2
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 3522
273, error=0xc0044000
