#19690 - 07/10/2000 05:18 connect a mobile phone via IR ?
bobo
Has anybodyallready tried to connect a mobile phone (with hardware modem like ericsson sh888, nokia7710, ...) to the empeg via IR ?
e.g. for e-mail checking, SMS display, empegNapster, ....
bobo
#19691 - 09/10/2000 02:01 Re: connect a mobile phone via IR ? [Re: bobo]
fvgestel
Loc: Netherlands
I tried installing gnokii on the empeg, without result yet;
It stated that irDA should be turned off. As this is compiled in the kernel, I think I have to recompile...
I did however manage to see some IR-traffic by sending a telephone-entry from my nokia 7110 to the empeg.
To accomplish this, an ioctl is needed to set /dev/ir to raw mode. I'm at work now, but will send my modified intercept.c when I get home.
I also noticed there's no ir_write function in the ir-driver; which device could be used for raw IR-transmission when irDA is disabled ?
Frank van Gestel
Frank van Gestel
#19692 - 09/10/2000 02:10 Re: connect a mobile phone via IR ? [Re: fvgestel]
You don't need to disable IrDA: the IrDA stack in linux needs to be connected to a low level IR device so it can talk IrDA. From memory, the IrDA transceiver on the empeg is on /dev/ttyS0 - which is what you should point gnokki at (or what you should do an "irattach" on to run IrDA).
/dev/ir is the consumer IR receiver, nothing to do with bidirectional IR.
#19693 - 09/10/2000 07:26 Re: connect a mobile phone via IR ? [Re: altman]
EngelenH
Loc: Belgium/Holland
/dev/ttyS2 I thought ... from the developer BBS if memory serves, or has it changed in Mk2 ?
Hans
Mk2 - Blue - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#19694 - 09/10/2000 07:33 Re: connect a mobile phone via IR ? [Re: EngelenH]
fvgestel
Loc: Netherlands
Just tested, it is /dev/ttyS2
My nokia 7110 pops up in /proc/net/irda/discovery...
Frank van Gestel
Frank van Gestel
#19695 - 09/10/2000 07:40 Re: connect a mobile phone via IR ? [Re: fvgestel]
EngelenH
Okay Frankie my boy ...
where can I find irutils ?
please pretty please !
Hans
#19696 - 09/10/2000 08:52 Re: connect a mobile phone via IR ? [Re: EngelenH]
fvgestel
Loc: Netherlands
irda & ir-tools as debian packages can be found at :
ftp://ftp.debian.org/debian/dists/potato/main/binary-arm/misc
or one of it's mirrors
BTW I've got IR-comm to work with my 7110 :>
here's how :
- install irda & ir-tools packages.
- edit /etc/irda/drivers :
- set serial device to /dev/ttyS2
- set type to infrared
- start irmanager : irmanager -d 1
- install minicom ( or another terminal emulator )
- set minicom to /dev/ircomm0 19200 8 n 1
- and off you go...
AT-command summary can be found on forum.nokia.com
Good luck...
Frank van Gestel
Frank van Gestel
#19697 - 09/10/2000 13:29 Re: connect a mobile phone via IR ? [Re: fvgestel]
EngelenH
If I was female I would want your baby been looking for that for days now.
Thanks Frank (that rhymes)
cheers,
Hans
#19698 - 09/10/2000 14:10 Re: connect a mobile phone via IR ? [Re: EngelenH]
EngelenH
This is interesting ...
When I wave my iPAQ in front of the Empeg and put it in IR receive mode ... it recognises my empeg as 'Linux' ... Of course since it is not trying to actually send anything .... still ...
This is very promising...
Hans
#19699 - 09/10/2000 14:34 Re: connect a mobile phone via IR ? [Re: EngelenH]
EngelenH
Even better, irpsion5 recognizes my iPAQ (it displays the device name) but then refuses to do anything because it sees it is not a psion 5
All together this makes my idea about hooking up an iPAQ to the empeg a lot easier
Hans
#19700 - 09/10/2000 15:53 Re: connect a mobile phone via IR ? [Re: EngelenH]
fvgestel
Loc: Netherlands
Thank you, but I've got enough of them... look here
We've also tried connecting with a philips VELO
it has a kind of hyperterm on it and we could get a login prompt from the empeg over IR by starting a getty on /dev/ircomm0
Look at my new kewl project that I will post to the BBS tomorrow ( well it is tomorrow! 00:32 )
It's a java applet which shows you the empeg's display in your web-browser.
It's really cool to see the empeg's visuals on your desktop.
Now I've got to find a way to control the empeg ir-device from another process...
Frank van Gestel
Frank van Gestel
#19701 - 14/10/2000 08:20 Re: connect a mobile phone via IR ? [Re: fvgestel]
bobo
anybody already tried the gsmlib test-apps ? the 7710 seems to be supported.
http://www.pxh.de/fs/gsmlib/
