#291797 - 28/12/2006 12:41 Another Excel question
Happy Birthday StigOE
Hi, all.
I have an Excel question that I hope someone knows the answer to...
I have a cell with a value and in another cell I would like to have the ASCII representation of the first value. I tried using Char(), but it seems it will only deal with direct numbers, not cells. Anyone know how to do this? I'm using Excel 2003.
Edit: Seems like, after some more testing, that it does in fact work also with cells...
Stig
Edited by StigOE (28/12/2006 13:10)
#291798 - 28/12/2006 23:30 Re: Another Excel question [Re: StigOE]
AndrewT
Loc: Oxford, UK
The simple solution is to copy the source cell and then (right-click) Paste Special -> Values into the destination cell(s). Alternatively, using the =value() inbuilt function may do what you need.
If neither of these are the solution you're looking for then it might help to have a bit more info on what you're looking to achieve.
#291799 - 29/12/2006 06:06 Re: Another Excel question [Re: AndrewT]
I managed to do what I wanted when I also used the HEX2DEC function as well (the values are hex values), but thanks for the suggestion. The formula I ended up with looks like this: =IF(HEX2DEC(D2)>25;IF(HEX2DEC(D2)<127;CHAR(HEX2DEC(D2));"");"")
Not pretty, but it works...
Stig
