Ok this morning I got the dreaded NO Hard Disk Found. A little history on the player. I bought the player off ebay less then a year ago. I upgraded to v3.01 and Hijack. I recently had started getting some fault errors and would every now and then get a No Hard Disk Found. A simple reboot would clear the problem. However this morning it does not seem to be going away. Last night the player took a little fall, about a foot off the bar on to the counter, but landed hard on it's side. This morning was the first time to power it up since the fall. I tried to do an "upgrade" and put v2.01 back on but that failed. I was able to put Hijack back on though through the logo editor. I can hear the drive spinning.
Before I opended it up I wanted to get your guys input on what to look for first, second, third, etc...
Bot log after putting Hijack back on.
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v477 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jul 13 14:42:45 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102880) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
Tuner: loopback=0, ID=-1
show_message("Hijack v477 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff84
ide_data_test: wrote 0xffff read 0xff84
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5584
ide_data_test: wrote 0x0000 read 0x1000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0x0000 read 0x3000
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:40
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
