#322325 - 18/05/2009 00:42
Finding duplicate files
I've been doing some cleanup on my ReadyNAS due to it running low on space. And for now, I have it back to a manageable size, but I know more can be done. Over the course of the years with various backup schemes, I know I've probably duplicated some files. So now I need an easy way of finding them. Anyone know of a good way to do this on an OS X box?
Ideally, I'd want to tell whatever program/script what paths to search, and I could have it look locally as well as on the NAS and inside disk images by having them all mounted prior to the check. It would be nice if the program just initially relied on filesize, then CRCs on files of the same size to sort out false dupes.
This is one of those programs that is hard to find, because Google is full of hundreds of unknown Windows utilities, even when you try to specify Unix or OS X only.
#322326 - 18/05/2009 01:16
Re: Finding duplicate files
[Re: drakino]
Loc: Florida
A quick Google search and I found two programs that find duplicate files. Tidy Up and DupeCheck. I would also recommend that you search http://osx.iusethis.com/ to see if any other programs are available.
Chad
#322339 - 18/05/2009 11:56
[Re: Attack]
I also found Duplicate Files Searcher, which is about as straightforward as you could name a program. Under Windows there's Doublekiller. Also under Windows, if you're interested in weeding out duplicate photos, I've been using VisiPics, which is really cool. It compares the photos, and will find resizes and I believe crops as well.
#322346 - 18/05/2009 13:37
Duplicate Files Searcher looks like it might work, I'll try it out later. DupeCheck is spotlight based so it won't work on the NAS, and Tidy Up is $30. I'll try free solutions first, but thanks for the pointer.
Windows is flat out for this, as I need to search inside several .dmg backups and also on my OS X desktop.
Also, thanks for the link to the iusethis.com site, never seen that before. Looks pretty handy for seeing what programs are popular.
#322350 - 18/05/2009 14:22
[Re: drakino]
Yeah, I figured that Windows apps weren't very helpful to you, but if anyone else needs this I thought I'd include it just in case. And again, that Visipics app is great, even if you can't use it on Mac.
Edited by Dignan (18/05/2009 14:22)
#322352 - 18/05/2009 14:55
[Re: drakino]
Loc: Florida
Also, thanks for the link to the iusethis.com site, never seen that before. Looks pretty handy for seeing what programs are popular. Use this tip to enable spotlight indexing on external volumes.
Chad
#322372 - 19/05/2009 00:20
[Re: Attack]
Enabling Spotlight via the terminal hasn't done anything, lsof still snows no activity after waiting a bit. Leopard may have disabled the workaround people found in the tip.
Also, I'm weary of Duplicate File Searcher now, after having it open some web page when I ran it.
The search continues...
#322388 - 19/05/2009 12:09
[Re: drakino]
Perhaps write a small bash/awk script to do the job?
#322390 - 19/05/2009 13:02
Perhaps write a small bash/awk script to do the job? Like this, perhaps? #!/bin/bash
# Find all duplicate files within the current directory and subdirectories.
# Requires /bin/bash, find, sort, and gawk.
find . -type f -ls | sort -n -k 7 | gawk '
function is_identical(fname1,fname2,fsize) {
if (fsize == 0)
return 1
return ! system("diff -q \"" fname1 "\" \"" fname2 "\" >/dev/null 2>&1")
function finddups(line,this_fsize) {
for (i = 0; i < 10; ++i)
gsub("^[^ ]* *","",line)
this_fname = line
if (fsize != this_fsize) {
if (fcount > 1) {
for (f1 = 1; f1 < fcount; ++f1) {
for (f2 = f1 + 1; f2 <= fcount; ++f2) {
fname1 = fnames[f1]
fname2 = fnames[f2]
if (is_identical(fname1,fname2,fsize))
printf "%s == %s\n", fname1, fname2
fcount = 0;
fsize = this_fsize
fnames[++fcount] = this_fname
END {
finddups("",-1)
finddups($0,$7)
#322428 - 20/05/2009 02:34
#322437 - 20/05/2009 11:14
I let the script run overnight, and woke up to a 1.2GB text file and the script still running. Lots of incorrect dupes, so I'm going to need to track down why that happened.
My experience with awk is pretty limited, so this is a chance to learn it a bit more.
#322438 - 20/05/2009 11:40
[Re: drakino]
find . -type f -printf '%20s %p\n' | sort -n | uniq -w20 -D | cut -c 22- \
| xargs md5sum | sort | uniq -w32 -D although you might need GNU uniq to get the -D option. Peter
#322440 - 20/05/2009 12:17
[Re: peter]
Ahh.. much more sensible. Thanks, Peter!
#322444 - 20/05/2009 13:42
[Re: peter]
although you might need GNU uniq to get the -D option. And the -w option as well. Side tangent, anyone else finding Google more annoying to search with lately? Trying to find the man page for GNU uniq required me to use "uniq", because if I left it unquoted, Google just automatically assumed I wanted unique.
#322454 - 20/05/2009 18:46
[Re: drakino]
Hm. Works without quotes for me.
