#38575 - 15/09/2001 22:18 Wiring
Terminator
Loc: Dallas, TX
Does anyone have a wiring loom lying around? I have 2 wires pulled out, and need to know which is which so i can get them back in place. What color are the wires for pin 8 and 9?
8 - serial pin 2 (RD)
9 - serial pin 3 (TD)
Thx,
Sean
#38576 - 15/09/2001 23:03 Re: Wiring [Re: Terminator]
bmihulka
Loc: Lincoln, NE
It looks like pin 8 is blue and 9 is yellow.
Brian
-See my empeg here-
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#38577 - 16/09/2001 16:39 Re: Wiring [Re: bmihulka]
Terminator
Loc: Dallas, TX
Thanks for the help brian. This wiring loom was the warranty replacement for the original one, and the exact same two wires have pulled out again. I contacted empeg support, and they suggest that I order another $130 sled. Instead of spending the money just to have wires pull out again, I thought I would get the fixed and back in place. Now to my next question - how do I get the pins backed out of the connector?
Thx,
Sean
#38578 - 16/09/2001 23:35 Re: Wiring [Re: Terminator]
They suggested a new sled for a broken loom??? Was this carsupport, and if so, do you have the emails in question? That isn't what should have been recommended!
#38579 - 16/09/2001 23:42 Re: Wiring [Re: Terminator]
Derek
Loc: NRW, Germany
If you slip a really thin screwdriver under the pin from the connector side (not the wire side) there is a small tab at the back you need to lift up. The pin then slides out the wire side of the connector. Should all come out really easily. If you need any force you are doing it wrong.
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 26GB blue)
#38580 - 17/09/2001 12:06 Re: Wiring [Re: altman]
Terminator
Loc: Dallas, TX
Yes I have the emails. Yes it was car support. I redirected them to you.
Sean
Edited by Terminator on 17/09/01 08:12 PM.
#38581 - 17/09/2001 13:53 Re: Wiring [Re: Terminator]
SE_Sport_Driver
"Those responsible for the sackings have been sacked."
32GB Mk. II in a WRX
Detroit, MI USA
www.PfeifferBeer.com
#38582 - 18/09/2001 03:32 Re: Wiring [Re: Terminator]
One of the support staff wasn't aware of the policy on wiring looms - he now is. Apologies for the incorrect advice you received.
#38583 - 18/09/2001 06:07 Re: Wiring [Re: altman]
Terminator
Loc: Dallas, TX
What is the policy, and what advice should I have received?
Sean
#38584 - 18/09/2001 06:42 Re: Wiring [Re: Terminator]
Wires falling out of sleds without provocation is a manufacturing fault, and we will fix them for free (even after the warranty expires) if they're sent back to us.
#38585 - 18/09/2001 09:42 Re: Wiring [Re: altman]
Why do I picture that being said with a Darth Vader voice?
"You're in command now... Admiral Piett..."
#38586 - 18/09/2001 21:30 Re: Wiring [Re: tfabris]
I was imagining something more artifical or robotic sounding
32Gig MK2 In 2001 VW Golf TDI
#38587 - 20/09/2001 00:38 Re: Wiring [Re: msaeger]
rockstar
lol, i wish i would have known that, considering i just soldered mine back together :)
