#572 - 21/09/1999 10:53 Whining help-repost
Sheetzam
Loc: Annandale, VA
Didn't get a response on the installation forum, so I thought I would try here.
Ok, I'll finally break down and ask for help. I have some fairly serious alternator noise on my installation, but it's fairly unusual.
1st the setup: 94 VW Golf.
Power cables for amp run down the driver side, all audio cables run down the passenger side.
The line out cables from the Empeg are wrapped in tape, so no grounding there. (Duck tape is insulating, right?).
The Sony Xplod amp is grounded only through the grounding cable.
The included grounding RCA cables are grounded to the grounding terminal on the amp.
Now the symptoms: The alternator noise changes in volume seemingly randomly. Some days it is almost non-existant, some days it is quite loud. The line noise is the
same on all four channels. The noise only exists when the empeg is running or paused.
Some observations: I don't think that the empeg's power in is running next to the line outs, but it's hard to tell in the cramped confines behind the Empeg what's going on
exactly. I'm also not sure if the Empeg chassis itself is grounded, and I'm not sure if it matters. I also don't know if the noise exists when the Empeg and it's sleeve are
removed from the DIN slot, i.e. not installed.
Any help or suggestions would be appreciated.
Sheetzam S/N 73, 10gig, blue
#573 - 21/09/1999 11:19 Re: Whining help-repost [Re: Sheetzam]
One suggestion - we've had reports of some bad connections inside the line-out phonos (though all the ones we've opened up to check seem very well soldered) - unscrew the hoods on the line outs and check that the signal & ground connctions are securely soldered in.
#574 - 22/09/1999 01:35 Re: Whining help-repost [Re: Sheetzam]
Happy Birthday schofiel
Following my install this weekend I can only suggest the following:
- connect a braided battery strap across the hinges of your bonnet to ensure the bonnet is properly earthed. This will form a good Faraday shield and reduce radiated field strength.
- check the alternator connectors are clean and greased with white vaseline.
- fit the VW suppressor kit that is available from the dealer. This includes the HV leads; not cheap, but worth it. My Polo was much improved when I did this years back.
- ensure that the filter supplied with the empeg is used, inline with the power feed to the unit, and that it supplies ONLY the empeg. If you saturate the coil with a high current, it will be affected by interference.
- measure the earth path resistance from the amp to the battery negative terminal; if it's more than a few milliohms, then the return current from the amp when operating at high volume will cause a voltage rise across the cable and jack up the earth reference for the amp.
- if possible, reduce the pre-amp input gain on the amp.
You describe the alternaotr whine level being randomly variable; this could be associated with battery charge state, ie. a flat battery will cause the regulator in the alternator to jack up current output. Most German cars use open-cage air-cooled high voltage rotors for compactness; trouble with this is, the regulator has to work harder. They have changed a lot of traditional designs from a rectifier bridge and regulator to a direct chopper/switching regulator setup years ago - this was started by Bosch, and quickly followed by AC Delco. Lucas stuck to analogue for a long time, although I'm not sure what they do now. The open cage means radiated field, and the switcher means interference.
So what can you do about this? The first and simplest thing I would start out by doing is looking at your battery state. Measure the voltage without the engine running, and for a 6-cell lead-acid you should be seeing between 11.5 - 12.5 V. If it's any lower, then your battery may not be charged or is low on cell electrolyte. It will not be able to hold charge well in this state, so you will need to see if you can get it topped up and re-charged. Alternatively, you could invest in a new battery of a higher Amp/hour rating than the one you have now. I recommend Bosch, but you can look for any make that has *large*, thick electrode plates, not tiny thin ones. When you install the battery, make sure that the terminals are greased with white vaseline, and that the earth lead is in good condition, with no corrosion around the contact point to the bodywork.
Now listen to the installation again and see if there's any difference. If not, then I would suggest you trace you power feed cables to where they are connected to the charging circuit. Does it go through a fuse? Check the fuse is clean and has not corroded it's contacts by rotating it/removing and re-inserting it. Grease up the contacts again. Measure the battery voltage at the battery, and then measure at the power feed to the empeg in-line filter. If there's any major discrepancy (around 1V or so), then you have a high-impedance power feed which will have to be re-done.
I can't think of anything else off hand other than manually moving connectors and cables while in motion one at a time to see if there's any effect. You could also try rotating the phono connectors through 90 degrees to see if orientation has anything to do with it.
Good luck - I would bet on a combination of corrosion, battery, and bonnet.
#575 - 24/09/1999 09:06 Re: Whining help-repost [Re: altman]
Sheetzam
Loc: Annandale, VA
Ok, tracked down the problem to the wiring loom. Some of the rubber insulators at the base of the line outs had split. Whenever they came in contact with the sled horrible line noise erupted. I think the change in temperature as the car warms has something to do with it as well.
Schofiel: I am using a rebuilt Bosch 90 amp alternator, and a fairly new Die Hard battery. I'll try the grounding strap on the bonnet, that may help. When I get the replacement wiring loom I'll measure the voltage differential. When I finished playing with it last night after discovered the broken insulation, I had the line noise down to almost nothing. This morning I set out to work, and it was all back.
Bottom line, I'll check all those things, and get back to the board with what I find. Hopefully someone will benefit from my experience.
Btw, I think the broken insulation is also affecting the line ins. When I tried playing my MD player through them, it sounded horrible. I'm waiting for the replacement loom to verify that it is in fact the broken insulation.
