Hi,
I've installed the "Viewer" onto my empeg (through the Bitt Faulk's empeg-preinit, etc.) and everything seemed to have worked well... until I tried to boot waiting for the "Viewer" entry to appear on the Hijack menu list... but it wasn't there :-(
I checked the boot on the hyperterminal and found out that something did not work well... Sigh!
Here's my booting strap:
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v235 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Mar 8 14:49:23 EST 2002
empeg-car player (hardware revision 9, serial number 30102695)
Command line: mem=16m
Memory: 14968k/16M available (1008k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a00).
empeg RDS driver initialised
empeg power-pic driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:87
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k inithijack: removed menu entry: "Home/Work Location"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Loading dancefile: "/empeg/lib/visuals/breakdance.raw"
Loading dancefile: "/empeg/lib/visuals/stonkdance.raw"
Loading dancefile: "/empeg/lib/visuals/princedance.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 6015695, error=0xc0044000
My empeg seems to hang at this stage... Anyone?
Thank you,
Alberto
